CDC not working
Started by JamesV6CDX, 07 August 2008, 17:52:48
The 4 disk changer in my dash - doesn't seem to recognise any CDs - I can only play music in the satnav slot :'(
Any ideas or suggestions, or is it just Fubar ?
tmx
faulty laser? try some head cleaner if that dont work pm davednd he fixes radios cdc's etc
QuoteThe 4 disk changer in my dash - doesn't seem to recognise any CDs - I can only play music in the satnav slot :'(
replace the cdc unit (same as cdc3), but keep your vertical board.
Quotefaulty laser? try some head cleaner if that dont work pm davednd he fixes radios cdc's etc
Could try Dave DND, but seem to recall that he struggles to get parts for these - Philips taken into Siemens who taken into VDO, and it seems all parts/support dropped with each takeover/merge
the head units fitted to facelift elites really are a pile of poo
Quotethe head units fitted to facelift elites really are a pile of poo
:o
Thats a bit of a statement.  They ain't the best, but I think that is a bit harsh.
And, tbh, if you don't want a chavvy look, finding a suitable aftermarket isn't easy...
Dave DND
Yeah, spares are getting almost non-existant now. If you can find a good single DIN CDC3 version from other Vauxhalls though, its an easy conversion to replace the mech / box with only the vertical pcb and fascia needing changing.
(Presumably you are using original discs and not recordable ones?)
Radio & Decoding Technician
www.dndservices.co.uk
Dave DND
:o
Not often I will stick up for an OEM head unit, but the CDC3 changer was actually a decent and well engineered bit of kit with only two minor faults - the plastic flap/switch on the front panel that breaks and the rapidly deminishing laser lifespan as soon as CDr`s are used.
The head unit that it connects with? Yes, OK, Pile of poo !!!   ;D
