Author Topic: Rear fogs not working  (Read 3028 times)
Snips
  • Nottingham / Stoke - on -Trent
« on: 17 August 2008, 13:50:43 »
Done a check of all my lights the other day and found out that both my rear fogs don’t work. Nipped down to Halfords for myself 2 lights fitted them and still nothing. When I turn them on the light comes up on the dash so show there on. I’ve checked all connectors are in properly but still having no luck,
Any suggestions
Adam
Re: Rear fogs not working
« Reply #1 on: 17 August 2008, 14:11:41 »
I bet you have a towbar fitted......if so check the state of the contact in the tow multiplug, its likely to be corroded and causing the fault.
Snips
« Reply #2 on: 17 August 2008, 14:55:43 »
had a look at all contacts and connectors and all seem to be fine, any thoughts on a wiring fault?
« Reply #3 on: 17 August 2008, 15:47:57 »
So, does it have a tow bar?
Snips
« Reply #4 on: 17 August 2008, 15:54:16 »
oo sorry yeah it does
unlucky alf
  • worksop, notts
« Reply #5 on: 17 August 2008, 17:04:14 »
if, like ive seen before that those horrible "scotchlocks"[blue square things] have been used on your t/bar wiring try squeezing them with pliers, personally i would junk them & use proper crimps with a ratchet crimper, those scotchlocks cause more trouble than they are worth.
Snips
« Reply #6 on: 17 August 2008, 17:26:22 »
hmm this is going to be a pain! there is about 3-4inch of wire then it goes into the bumper where i presume those horrible scotchlocks can be found
unlucky alf
  • worksop, notts
« Reply #7 on: 17 August 2008, 18:08:22 »
lets hope you havent got any but id be surprised if there isnt, but would have thought that they would be inside the car probably not to far away from one of the light clusters, its the matter of tracing backwards from the t/bar socket itself.
bigall
  • merseyside
« Reply #8 on: 17 August 2008, 21:53:44 »
http://www.omegaowners.com/forum/YaBB.pl?num=1212700632
look here . Your problem is to do with the wiring of the fog lights .whoever wired your towbar connected to the fogwire for the trailer and not the one for the car - quite a common problem
I drive a moneypit Omega - at least its comfortable!!!!!  200k approaching rapidly!!!!!!!!! "") (must change oil soon)
