Author Topic: wiring prob with self levelling suspension  (Read 1924 times)
Varche
  • middle of Andalucia
    • Golf Estate
« on: 21 August 2008, 17:56:11 »
Story so far. Suspension levelling stopped working.
Removed sensor arm at back to see if that would prompt it into action. Nothing
Swapped top row relays in fuse box (marked 407) still didn't work. Fuses seem to be OK but TBH not really sure which is the right fuse. Which one is it ?
Removed compressor and air tank and tested by connecting black/green and black wiresd to battery. Unit works and sucks air in and blows air out of the other pipe.
Repeated by shorting out the same wires to wires between the connecting block in the loom under the offside headlight NOTHING.
I am concluding that it is a fault somewhere electrical.
Any suggestions gratefully appreciated.
varche
« Last Edit: 21 August 2008, 18:02:24 by olive »
