Author Topic: When You Input The Stereo Code...  (Read 1902 times)
MutantCav
  • Gainsborough
« on: 22 August 2008, 18:43:37 »
How do you know if it has or hasnt accepted it as correct if the stereo is already up and running???
Tried the AS thing to input the code and all is as it should be...checked out the code for the stereo and put it in (in this case a CDR500) however if I put in a wrong code, the stereo still came on and there was no noticable difference...also when the stereo was initially put in it didnt ask for a code anyway and worked fine...
Also tried this with a CCR800 and seems to be the same...doesnt come up with safe 10 like when entering CD changer code...just says CODE then the 4 ---- to input code...
unlucky alf
  • worksop, notts
Re: When You Input The Stereo Code...
« Reply #1 on: 23 August 2008, 10:04:20 »
hi CHRIS, sounds like it has been de-coded, quite common as people have it done after losing the code or got the car without the stereo code.
« Reply #2 on: 23 August 2008, 10:09:08 »
Moving to ICE/Electrical, as more appropriate
Dave DND
  • DND Services Ltd
    • Paignton, Devon
    • DND Services Ltd
« Reply #3 on: 23 August 2008, 17:07:53 »
The CODE number function has been turned off. Until it is reactivated, the code will not be required nor accepted.
Radio & Decoding Technician
www.dndservices.co.uk
