Pages: 1 [2] 3  All   Go Down
Author Topic: Cant find any cd changer cables  (Read 8249 times)
Tonybazza
  • Lapford Devon
Re: Cant find any cd changer cables
« Reply #15 on: 21 August 2008, 13:14:26 »
might find it where it comes through between seat and boot, but if its been cut, may be easier to replace loom from drivers footwell...
Hi again if this is the case where can i find the cables in the footwell ? and will this be on a connecter block or will i have to brake the loom please advise on my next move.
Thanks Tony
« Reply #16 on: 21 August 2008, 13:41:02 »
Thanks Tony
The CD cables run to a connector block behind the right side panel in the drivers foot well. I would obtain a loom from a scrapper and replace this self contained loom.
Tonybazza
  • Lapford Devon
« Reply #17 on: 21 August 2008, 13:59:21 »
Thanks for you quick reply i will go down that route i will also put a add in the wanted section will this be a hard job to do ? do you have to take lots of panels of or can i put the changer under the passager seat?
Thanks Tony
« Reply #18 on: 21 August 2008, 14:02:53 »
Thanks Tony
Easy enough to do, you simply remove the drivers kick panel and the sill trims on the drivers side...
Tonybazza
  • Lapford Devon
« Reply #19 on: 21 August 2008, 14:13:50 »
Thanks
I cant seem to post in the wanted area if anyone has the part that i am looking for please Pm or email.
Thank you all for your help great site.
Tony
Tonybazza
  • Lapford Devon
« Reply #20 on: 21 August 2008, 18:00:41 »
After taking the panels of from the front drivers footwell i have posted some pics please can anyone tell me what wires i am looking for as i still cant find the wires for the cd changer (well i dont know what i am looking for really)lot of wires but nothing says cd changer on in bright yellow pen lol.
Thanks Tony p.s what does that silver box with an aereil do is it some amp ?
Tonybazza
  • Lapford Devon
« Reply #21 on: 22 August 2008, 17:35:55 »
Please can anyone help with my last post as i have still got half the car in bits lol. and we are of shopping tomorrow
Thanks
Tony
« Last Edit: 22 August 2008, 17:36:56 by Tonybazza »
« Reply #22 on: 22 August 2008, 19:57:29 »
in the kick panel (the plastic panel behind bonnet realease) you will see a large connector in from of alarm ecu, with some loopback cables in it and the rest going down the sill....
Tonybazza
  • Lapford Devon
« Reply #23 on: 23 August 2008, 11:18:50 »
Hi i cant find any such cables in the footwell could have been taken right back to the head unit ?
my local bracker has a p reg with a philips changer in the boot can i take the cable from that and if so can i take it back to the head unit what shoul;d i be looking out for?
Thanks again but i would like to get this done today oneway or the other. i am running out of good tapes to play lol.
Thanks Tony
« Reply #24 on: 23 August 2008, 11:52:24 »
Thanks Tony
Philips one no good.
Take a picture of the ecu mounted behind the plastic kick panel behind the bonnet release lever.
Tonybazza
  • Lapford Devon
« Reply #25 on: 23 August 2008, 11:59:08 »
Thanks for your reply i have put some pis up they are already up i hope put them up 2 days ago.
Thanks Tony
« Reply #26 on: 23 August 2008, 17:08:37 »
Thanks Tony
None of behind that kick panel though.
Tonybazza
  • Lapford Devon
« Reply #27 on: 23 August 2008, 19:36:00 »
Hi am i being a total nut but the pics i have uploaded before are from behind the black panel to the right of where your right foot would be and the bonet release leaver is !! i have uploaded some more from a dif angel if this is the wrong place then i am stumped but i see no big conector but thanks for your time trying to help.
Tony
« Last Edit: 23 August 2008, 19:43:08 by Tonybazza »
« Reply #28 on: 24 August 2008, 15:29:14 »
You see in first pic a large ecu with GA on it? See it has a threaded stud either side of it? That is where the large connector normally is.  Yours isn't there  :-/
MutantCav
  • Gainsborough
« Reply #29 on: 24 August 2008, 16:27:50 »
The loom to the head unit is missing too then...should be a lot of fun putting all of that back!!
Pages: 1 [2] 3  All   Go Up
