Pages: [1] 2 3  All   Go Down
Author Topic: Cant find any cd changer cables  (Read 8251 times)
Tonybazza
  • Lapford Devon
« on: 20 August 2008, 14:55:52 »
Hello all i am new to this forum so please be kind lol.
I have just got a 2lt cdx t reg that had a jvc all in one head unit with no cd changer got a ccr600 and cdc2 from fleebay hoping to get the stearing wheel controls to work .
installed the head unit and all controls work fine very happy but i cant find any wires in the boot for the cd changer ?
whould there be any ? if so where? and if not can i get some and is it easy to install.
Thanks Tony
tmx
  • Herefordshire
    • 3.2 MV6 2002
Re: Cant find any cd changer cables
« Reply #1 on: 20 August 2008, 16:50:53 »
it usually lives in the boot in the same compartment as the first aid box The Boy will problably know if its pre wired or not! if its not then its only slightly challenging to wire it in
« Reply #2 on: 20 August 2008, 18:10:46 »
cdx should have the cd changer cable.  It should be around the cubby hole in the boot, drivers side.
Tonybazza
  • Lapford Devon
« Reply #3 on: 20 August 2008, 18:56:00 »
Thnaks for your replies i have looked everywhere in that location the only wires that i can see are 1 large wire going up and into the rear window area behind the uper part of the rear seats and some coming from a black unit just back from where the filler pipe is heading to the number plate area nothing that looks right.
but at the fascia end i have all the right wires and my info screen shows the radio channels and when i go to the cd it says not conected.
please can you adv the best way to over come this i.e new cable where to get one from and the best way to fit .
i live in devon near crediton so if any member is close by and fancies making a few quid to help me out that will be ok to.
Thanks
Tony (just listening to some old tapes lol)
« Reply #4 on: 20 August 2008, 19:21:11 »
changer cable is cable tied to the ridge on wheel arch that you can see from cubby hole.
Tonybazza
  • Lapford Devon
« Reply #5 on: 20 August 2008, 20:28:24 »
Thanks again for your quick reply i have had a good look and cant find any i have added some pics . am i looking in the right place??
if so what can i try next.
« Reply #6 on: 20 August 2008, 20:50:43 »
Yup, thats missing ;D
might find it where it comes through between seat and boot, but if its been cut, may be easier to replace loom from drivers footwell...
« Reply #7 on: 20 August 2008, 20:57:10 »
Check the drivers foot well, see if its been removed right back to there.
« Reply #8 on: 20 August 2008, 20:58:44 »
Does the aerial amp wiring run in same loom?
« Reply #9 on: 20 August 2008, 21:02:32 »
The switched radio feed is in that connector to support the bose amp but, the feed fo the aerial amp is not in that loom, it runs down the other side.
« Reply #10 on: 20 August 2008, 21:03:27 »
Ah right :y
Tonybazza
  • Lapford Devon
« Reply #11 on: 20 August 2008, 21:17:54 »
Thanks all. My nieghbours think i am mad sat in the car taking pics of the seat lol but it had to be done i found these wires behind the seat after pulling some carpet away the wire has been cut and taped up am i on the right track if so can you buy the connector that would fit into the cd changer that i could rewire from where its been cut?
thanks agian for your help but this is fun lol.
Tony
« Reply #12 on: 20 August 2008, 21:22:52 »
Somebody has been fitting an amp or chav box
Remove the seat back side, and photo that (remove bench, then you'll see a tab that holds seat back side in place - bend this, then lift the side out)
Tonybazza
  • Lapford Devon
« Reply #13 on: 20 August 2008, 21:50:45 »
Thanks again i am not to sure what you want me to take out but i keep finding wires first i cant find any now i have loads but still dont know what to do lol.
[img]
« Reply #14 on: 20 August 2008, 21:59:49 »
Don't join them all together!
Seriously if you are looking for connectors/plugs ask on here under parts wanted - lots of people are breaking omegas and would supply a length of loom cheaply.
Pages: [1] 2 3  All   Go Up
