cig lighter and front drivers heated seat
Started by johnnycboy, 31 August 2008, 18:04:52
johnnycboy
QuoteDid you check fuse 14 ?
As both the f*g lighter and seat heater's run through that.
yes mate, checked already.
johnnycboy
update - had climate panel out and found that someone had put a bullet connector on the back of cig lighter, now seems to work - burn on finger to prove it.  problem i have now is radio (ncdc 2013) is playing classical music and gid only showing BOSE.  Any help appreciated :'(
Quoteupdate - had climate panel out and found that someone had put a bullet connector on the back of cig lighter, now seems to work - burn on finger to prove it.  problem i have now is radio (ncdc 2013) is playing classical music and gid only showing BOSE.  Any help appreciated :'(
Does the backlighting on the NCDC2013 light up, and if not, do steering wheel controls work for it?  If so, I bet the front panel has come adrift.
Actually, I'm talking partial 'dangle berries', as display would still show relevent info. Display has to be due to no comms with radio.
johnnycboy
ill take radio back out and check connections, cheers tb
I seem to recall these NCDCs go into a limited capability if it can't find its paired screen...
johnnycboy
Quoteall sorted thanks guys :y
Poor connection on back?
johnnycboy
#23
yep hadnt quite made it home, cheers. pushed it in a little further and hey presto it came on:y
