cig lighter and front drivers heated seat
Started by johnnycboy, 31 August 2008, 18:04:52
johnnycboy
I have two questions hopefully someone can help with!
Front cig lighter does not work, rear one does, I have checked voltage to lighter as expected no volts there - question how do i remove the unit to check connections at back?
Drivers heated seat not working, anybody point me in the right direction of where to start looking?
TIA
Lighter - see my post in maint guides about climate panel removal, all should become clear.
Heater, likely failed heater pad.
johnnycboy
Beconboy
i,ll lend you a lighter if you ask nicely Jon :y
johnnycboy
just had lighter out, no feed from back connector (brown wire), next thing is to take climate panel out, the ncdc 2013 stereo has removal holes further apart than a standard hu, is there any other way of extracting the hu or is it tool buying time :question
Beconboy
johnnycboy
#6
Quoteis that the 2 prong type jon
no
i have these already, the ones on the 2013 are spaced further apart
and spell my name right :o
Beconboy
no
All good In Car Entertainment shops sell the wider spaced ones, even Hellfrauds.
Or "adjust" either yours or a wire coat hanger! :y :y :y
johnnycboy
QuoteOr "adjust" either yours or a wire coat hanger! :y :y :y
could be a goer - cheers paul 8-)
4 nails is what i use when I can't find the tools.
johnnycboy
Quote4 nails is what i use when I can't find the tools.
have to grow some more hands then ;D ;D ;D ;D
cheers i'l have to give it a try 2morrow then. :y
iainb
Did you check fuse 14 ?
As both the fag lighter and seat heater's run through that.
