Steering wheel controls
Started by TheBoy, 31 August 2008, 01:06:32
Dave DND
QuoteLights should go off when switched off / powered off, and for those that stay on, this needs to be checked, as its not just the led`s that are on, it is often powering external circuitry as well by default
Forgot to mention, this is for aftermarket stuff - unsure if applicable to OEM fitment.
Most Vauxhall radios can be turned on without the need for an ignition key, and will usually time out and switch off after an hour - this tends to be a feature of the head unit, and not of any vehicle circuitry though. May help explain why some lights are on?
Radio & Decoding Technician
www.dndservices.co.uk
2015 is stock. So yes. it was my assumption that the lights stayed on for the 1 hour period after the ignition was turned off. I have noticed i quiet hiss from the speakers while working on the car, presumably for the same reason. I had also presumed all elites had 2015, whats the diff.? not that its relevant.
OK, seems normal for the NCDx factory fit one to leave the steering wheel controls on for a while then :)
