Steering wheel controls
Started by TheBoy, 31 August 2008, 01:06:32
Should they light up when ignition is off?
Are they LEDs or bulbs?
QuoteShould they light up when ignition is off?
With the key out & car locked up? Mine are off then!  ;) but with the key out & the radio on, they are lit!
QuoteAre they LEDs or bulbs?
Err? Pass  ;)
Mine come on whenever the radio is on, regardless of headlights, etc.
QuoteMine come on whenever the radio is on, regardless of headlights, etc.
Yep, like he said.
Yeah, thats what I thought should/would happen, cheers guys :y
Mine seems to be behaving somewhat differently, they stay on for a while afterwards...
markey mark
Quoteand yes they are leds  :y
Ta. Not going to have a hit on the battery then.  Though looks like they go out after an hour or 2 anyway.
I have no idea why they stay on that long though...
with this and the glove box post... Have you got a new motor or something?
Just been out to the car in the dark. S wheel lights did not come until radio turned on. Radio off lights off shut door lock car. S w Lights stayed on for a good 10 mins and where still on when i left it. Presume they stay on while the radio is still "live" and they go off after that time has expired. Never noticed that before.
SP_3.2
Same with mine stay on for sometime after engine is off.
Danny
mine also stay on for a while after engine off
Those that stay on, what radio you got?
QuoteThose that stay on, what radio you got?
Siemens 2015.
Dave DND
Remember if fitting an aftermarket radio, the IGNition and PERManent lives will be swapped over - we all know how to do this for the head unit, but many of the aftermarket steering adaptors can often be wired incorrectly, so may be worth checking the wires with a meter at both ends of the steering interface box and altering accordingly.
Lights should go off when switched off / powered off, and for those that stay on, this needs to be checked, as its not just the led`s that are on, it is often powering external circuitry as well by default.
Radio & Decoding Technician
www.dndservices.co.uk
Siemens 2015.
Mine do as well
Siemens 2013
