Cruise still not working
Started by alexandjen, 23 July 2008, 22:14:54
alexandjen
QuoteI see you're down as a possible for WIM ;)
Mmm yes still possible  :-/
Trade club card holder
Code scanner available
Sir Sideways
Anyone know if I would need a clutch switch since converting it to manual?
alexandjen
Would of thought so otherwise when you change gear the cruise will not disengage  :y
MutantCav
The question would be...does cruise still work since you converted?? If it does then in theory no you dont need it...the clutch switch cuts out the cruise when you change gear...no switch it stays on cruise until you brake, just like an auto...no idea though how that would affect the cruise control box...might send it incorrect signals or something...
davlad22
QuoteSince I converted mine to a manual I've lost cruise, just need (a clutch switch?????) and a nice person with a tech 2 to sort it in exchange for some beer tokens..............
I must admit, to show my ignorance, that I never knew a manual could have cruise control! :o :o  I suppose this is because I have only ever had cruise control with automatic cars! ::) ::)
Liz, even our DIESELS have cruise! How times change lol!
Disengaging the cruise via clutch doesn't work very well, it's a bit jerky and should only be used as a failsafe, like the brakeswitch.
Mutant, I think you are most probably correct about needing that clutch switch for the cruise to work for Sideways.
*Admin* when quoting Lizzies post it doesn't put the correct username in the brackets??
Correct, it uses her login name :y
davlad22
Apologies, i'd forgotten the two were different  :-[
.....pass me coat please mate  :-X
alexandjen
#22
Well I've rewired the towing electrics today.
I've now wired the 7 core dieectly to the cars loom (the one provided in the boot)
I had a 7 way bypass relay originally and I thought this may have been the cause of my non functioning cruise as it stopped working around the same time.
I had scotch locked onto the brake feed originally but am now using the feed provided in the towing loom.
Wrong again.......It still doesn't work :(
Just to recap, I've now changed the stalk, brake switch and have unplugged the clutch switch wiring and bridged the connections to rule that out.
Is there anything else left to try other than a talk with Tech II?
