Cruise still not working
Started by alexandjen, 23 July 2008, 22:14:54
alexandjen
Have now changed stalk and brake switch, still no joy  :(
Apart from the clutch switch is there anything else I could try?  :-/
Trade club card holder
Code scanner available
PaulW
with yours being DBW car, would best be hooked upto a tech2 for some diagnosis
Humbugs...
Debs.
QuoteHave now changed stalk and brake switch, still no joy  :(
Did you have cruise 'enabled' via Tech II after installing the stalk and brake switch?
alexandjen
vehicle originally had cruise and was working but suddenly packed up  :(
alexandjen
Unplugged clutch switch this evening and bridged the two connections within the plug to complete the circuit thus bypassing the switch.............................................still no cruise  :'(
It's got me thinking back to when it first stopped working and what else I have done to the Mig.
At about the same time a brake light bulb blew and I replaced it.
I also wired in twin towing electrics around the same time, does anyone think either of these two are in any way related to my lack of cruise?
markey mark
could quite easy be john try putting it back to standard and some top quailty bulbs in  :y
alexandjen
Surely you don't mean disconnect all the wiring to the twin electrics Mark?
I'm going to get some brake light bulbs from Vx tomorrow as I'm sure the bulb I used was not a Vx one.
By the way I see the price has gone back up for your MV6  ::)
markey mark
QuoteSurely you don't mean disconnect all the wiring to the twin electrics Mark?
yes redid the ad and took some better photos today if it dont sell straight away no worries will sell sooner or later !! shouldnt have to short change mesen just to get rid !!  :y :y
mabye just the connection to the brake light circuit  :y
A chat with a tech2 would point you in right direction.
Sir Sideways
Since I converted mine to a manual I've lost cruise, just need (a clutch switch?????) and a nice person with a tech 2 to sort it in exchange for some beer tokens..............
Sir Sideways
Thinking about it, if the ecu was told its now a manual then I would of thought it does need a clutch switch.
Jim
alexandjen
QuoteA chat with a tech2 would point you in right direction.
^^Agreed^^.............changed both brake light bulbs for new Vx bulbs this evening..............no cruise  :'(
I see you're down as a possible for WIM ;)
FRE07962128
QuoteSince I converted mine to a manual I've lost cruise, just need (a clutch switch?????) and a nice person with a tech 2 to sort it in exchange for some beer tokens..............
I must admit, to show my ignorance, that I never knew a manual could have cruise control! :o :o  I suppose this is because I have only ever had cruise control with automatic cars! ::) ::)
Yup, manuals can as well.  Arguably not as useful (as clutch turns it off), but still nice on a long run
