Author Topic: Just tried a 2nd sat nav cd still not working help  (Read 3485 times)
garbage456
  • Carshalton, Surrey
« on: 05 September 2008, 20:00:03 »
from an omega facelift 2001, siemens 2013 sat nav, monochrome.
I just made a back up of sat nav cd as i thought my old one was damaged but that still isnt working, Sat Nav still thinks i am in the next town, what can I do please?
thanks
« Last Edit: 05 September 2008, 20:27:39 by garbage456 »
    • 530D M Sport, 330i Coupe
Re: Just tried a 2nd sat nav cd still not working help
« Reply #1 on: 05 September 2008, 20:37:16 »
Do you have a good GPS signal?
garbage456
« Reply #2 on: 06 September 2008, 06:50:35 »
thanks for your help
yes i am in the south of london and the gps signal it gets now seems to be about 1 mile out.
MutantCav
  • Gainsborough
« Reply #3 on: 06 September 2008, 07:50:29 »
Sounds like the disk is working ok but the GPS signal is out somehow...I wonder if you can reset the system somehow...
Dave DND
  • DND Services Ltd
    • Paignton, Devon
    • DND Services Ltd
« Reply #4 on: 06 September 2008, 07:56:04 »
I`d suggest to try changing the GPS receiver - a favourite to fail and would give a very similar problem to the one you are experiencing.
Radio & Decoding Technician
www.dndservices.co.uk
garbage456
« Reply #5 on: 07 September 2008, 10:10:18 »
hi thanks for that, any idea where it is and is there any guides that can help?
thanks
« Reply #6 on: 07 September 2008, 11:52:41 »
It's the foot part of the roof aerial.
There's a link in the drivers kick panel and obviously the link to the back of the head unit, i'd check those first!
garbage456
« Reply #7 on: 07 September 2008, 18:29:16 »
thanks,
garbage456
« Reply #8 on: 13 September 2008, 08:16:25 »
its working again, i have tried for 3 weeks and every day it was not working right, but now its working again !!!
« Reply #9 on: 13 September 2008, 10:06:34 »
For both Carin and Siemens based units, I got new GPS receiver from a company on egay called Allendale Stores (or similar), about 7 quid delivered iirc.  Its type you put in corner of dash (for Seimens) or on Parcel shelf (for Carin) - (only comes with 3m cable, so needs to be near unit).
Can't remember which is which, but one is SMB-M and other is SMB-F
The double DIN siemens may need jiggery pokery, due to custom plug (to hold it in cage).
