Fitting carin to my mini face lift
Started by JonArgraig, 12 September 2008, 18:47:11
QuoteRighto off to check my speed pluse,
Just to double check - which colour wire is the speed pluse in the main loom, I think its white with a black trace but not sure as not in the car to look
sounds about right....   ....or is that reverse sensor?
does the unit claim you are moving, but just not in right area? If so, use the Car Location option under settings :y
JonArgraig
Right - it's not getting a speed pluse - if some one can confirm the right wire's I'll sort it in the morning
JonArgraig
#17
oh and the map disk is so old it's doesnt seem to have Holyhead on it... would also be causing a problem ?
well the arrow spins around a little and the GPS Long/Lati do update - but it has me in the same road in Kent still...
no speed pulse then - there are 6 wires you need to connect in passenger kick panel, most being power and illumination (to dim display when lights on). but you also need reverse and speed...
JonArgraig
Ah, reverse worked when I tried under settings mode, just not counting the pulses,
I'll check my wiring tomorrow in the light
Thanks for the input :)
JonArgraig
Right, now I have a upto date disk in it know's it out side my house, I cant find any thing a miss with the wiring but if some on could confirm
White T-Black (Speed)
Grey T-Yellow (Lights)
Blue T-Red (?)
Grey T-Green (?)
QuoteRight, now I have a upto date disk in it know's it out side my house, I cant find any thing a miss with the wiring but if some on could confirm
Blue T-Red (?)
Grey T-Green (?)
I have circuit diag here, but images server looks like its gone tits up and wont let me upload currently
Speed Pulses = Blue/Red
Reverse = White/Black
Lights = Grey/Green
W contact = Brown/Red
Permenent 12v = Red
0v = Black
Which don't entirely maych yours
JonArgraig
QuoteSpeed Pulses = Blue/Red
Lights = Grey/Green
Permenent 12v = Red
0v = Black
Just got back in to find your post... and your right...
BEACUSE IT WORKS !!!
Thanks TB :p
MutantCav
JonArgraig
Well for the age of the system I'm truly impressed :)
the update map makes a massive difference though  :y
QuoteWell for the age of the system I'm truly impressed :)
My biggest grief with it is speed of entering destination.  That aside, I like it, and with up to date maps, is very useful.
