Fitting carin to my mini face lift
Started by JonArgraig, 12 September 2008, 18:47:11
JonArgraig
The site that listed all the colour codes for the loom on the mini face for fitting Carin is down.
any one know what they are?
QuoteThe site that listed all the colour codes for the loom on the mini face for fitting Carin is down.
If your TC switch is above the radio, it will have the plug.
Or is your TC switch to left of radio?
JonArgraig
I dont have the plugs, and the TC button is the large one to the left of the radio,
I do how ever have the full loom front to rear for the carin system.
JonArgraig
ok peeps, I've got this fitted now but...
Even though it shows it can see 5 to 8 sats, depending where i am - It thinks Im down south some where, also the Long/Latatude does not up-date, any idea's ?
philhoward
I think this was in another post recently - SatNav mouse on its way out.  Think it was Dave DND who mentioned it...but can't find the thread..
Running an X30XE in a Reliant Scimitar GTE as I can't have an Omega as a company car...
Dave DND
If only just fitted, it may need a bit of time to adjust and locate itself, as it may still think its in the previous car !! - best thing is to go for a drive for 20 mins or so, and if you have 5 sats showing as claimed, it won`t be long before it has found itself on the map.
Radio & Decoding Technician
www.dndservices.co.uk
JonArgraig
QuoteIf only just fitted, it may need a bit of time to adjust and locate itself, as it may still think its in the previous car !! - best thing is to go for a drive for 20 mins or so, and if you have 5 sats showing as claimed, it won`t be long before it has found itself on the map.
Done around 120 miles tonight - up to 8 sats at one point and still thinks it's in Kent...
Going to try a new GPS mouse on it tomorrow
JonArgraig
tried another GPS mouse - from my tracker thingy and it didnt pick any up :(
Though the Long and lat's do up date its a fair few miles apart when it does and it does not update the location.
does this still point at the GPS mouse ?
MutantCav
Dave DND
QuoteCould it be the wiring???
Check that the speed pulse wire is working and that the screen installation menu shows that the pulses are being picked up.
JonArgraig
Do you know the code for the setup screen by any chance ?
right. stop.
The Carin system uses gyros and speed pulses to dettermine location, with GPS as a secondary (and unnecessary) locator.  Which makes it fantastic in cities/tunnels/Birmingham's inner ring road!
In Settings is a Car Location function where you tell system the jnc your car is at.
HTH.
The Siemens/VDO ones integrated into Stereo utilise the sats as you would expect, and need about 15mins of driving after car moved on low loader etc to restablish precise location.
And lastly, if your hardware is SY581 and you are running firmware less than v2.3, get it updated - v2.3 puts in nearest town automatically, which saves time...
JonArgraig
Righto off to check my speed pluse,
Just to double check - which colour wire is the speed pluse in the main loom, I think its white with a black trace but not sure as not in the car to look
