central locking
Started by steve1, 21 September 2008, 19:31:51
steve1
central locking not working buttons on key work lights flash but doors do not lock or unlock could it be a fuse or relay.
Quotecentral locking not working buttons on key work lights flash but doors do not lock or unlock could it be a fuse or relay.
Presumably it locks/unlocks with key?
If so, have you tried resyncing the remote to car (Ign on, press the remote buttons, and car locks/unlocks)?
steve1
yes locks with key will try to resync as you suggested.cheers
steve1
does not work after resync any other advice wouldbe appreciated
Quotedoes not work after resync any other advice wouldbe appreciated
Did it used to work?  If it is new to car, it needs to be programmed to car
steve1
dont no if it used to work,only had car 2weeks,how do you programe it?
Quotedont no if it used to work,only had car 2weeks,how do you programe it?
Sadly, thats a job for a Tech2 diagnostic scanner (real one, not cheapo).
steve1
#7
could it be a relay or something like that? where can i get an owners manual.please
Quotecould it be a relay or something like that?
unlikely.  Could be a fault in alarm (CD or higher spec) or central locking (GLS) ecu, but more likely a fob fault or simply wrong fob...
steve1
what can i do if fob fault or wrong fob
Quotewhat can i do if fob fault or wrong fob
If faulty fob, repair or replace (replacement will need programming to car).
If wrong fob, it will need to be replaced with correct type, and programmed to car.
If correct fob, and a working fob, but never been programmed to car, this will need to be done.
Firstly, is it a fob integrated into key?  If so, look at the back, and there is a small area that is untextured.  Look carefully (try different lighting conditions) and you will see writing.  What does it say - particularly looking for make, eg Megamos, Delphi, Bosch etc.  Then state what model car you have (GLS/CD/CDX etc)
steve1
there is no writing on the fob,on the key there is the number 105 thats all.
steve1
opened up fob it is a megamos i have a cd
Quoteopened up fob it is a megamos i have a cd
Sounds the right fob.
You say the LED lights up, but neither lock/unlock functions work, even after attempting resync (did doors lock/unlock during resync?)?
steve1
led lights work,indicators flash when buttons pushed but no lock /unlock,resync did not work does engine need to be running when trying to resync?
