What wiring?
Started by Recovery_Russ, 27 September 2008, 17:56:19
alexandjen
QuoteSo will a blind from an Elite fit straight into a CDX parcel shelf?
Blind will go but underside of shelf needs to be butchered a bit to allow clearance for motor. Then you have to sort out how to fit blind to shelf as on "ready cut" shelf there are six screw studs fitted to allow blind to be bolted on. IMHO you`re better off trying to source another shelf
Thanks Rob, I'll look around for a blind fitted to a shelf then ::)
Blind switch for the console is just under £12 from main dealers
Thanks again Rob, don't know anyone who has got a shelf complete with blind for sale do you?
Fleabay item no; 110292917348. Not a bad price :y
Thanks yet again Rob, will a prefacelift shelf fit in a facelift?[/quote]
Parcel shelf will fit entire range :y
Excellent cheers :y
Trade club card holder
Code scanner available
alexandjen
Is the switch the same across the range also?
QuoteIs the switch the same across the range also?
No. Facelift totally different to others. :)
Facelift switch sits under hazard switch :)
alexandjen
QuoteFacelift switch sits under hazard switch :)
:y Thanks :y
:y Thanks :y
When I got my switch had to pay for it up front and wait two days. Not a stock item :)
alexandjen
:y Thanks :y
Is it on trade club?
alexandjen
QuoteNo :)
Ok cheers Rob :y
