What wiring?
Started by Recovery_Russ, 27 September 2008, 17:56:19
Recovery_Russ
Under my current non rear blind shelf i have a small plug taped up at the left hand side which i assume is for the blind when i fit it, but on the right hand side i have another plug and an aerial type co-ax cable. What are these for? My radio is a ccrt700 with phone and have good signal both phone and radio so i'm assuming its for something else. But what?
Grey one by any chance?
Recovery_Russ
Yeah with a screw fit type connector
QuoteYeah with a screw fit type connector
My loom has that, no idea what for.  End up in Bose shelf...
Think it may be something to do with GPS unit fitted to some CCRT700 radios.
alexandjen
So will a blind from an Elite fit straight into a CDX parcel shelf?
Trade club card holder
Code scanner available
QuoteSo will a blind from an Elite fit straight into a CDX parcel shelf?
Blind will go but underside of shelf needs to be butchered a bit to allow clearance for motor. Then you have to sort out how to fit blind to shelf as on "ready cut" shelf there are six screw studs fitted to allow blind to be bolted on. IMHO you`re better off trying to source another shelf
alexandjen
Thanks Rob, I'll look around for a blind fitted to a shelf then ::)
Blind switch for the console is just under £12 from main dealers
alexandjen
Thanks again Rob, don't know anyone who has got a shelf complete with blind for sale do you?
No mate, sorry. I got a blind but no shelf :)
Fleabay item no; 110292917348. Not a bad price :y
Bumbazor
That guy's got lots of other good stuff too. Worth watching.
alexandjen
Thanks yet again Rob, will a prefacelift shelf fit in a facelift?
Thanks yet again Rob, will a prefacelift shelf fit in a facelift?[/quote]
Parcel shelf will fit entire range :y
