aeriel
Started by jonna, 04 October 2008, 19:27:54
jonna
 please help!!!!! i've just bought an omega 2.6 elite estate and part of the aeriel is missing. it's got a built in phone and sat nav. the sat nav works fine but not the radio. i've been to a v/x dealer this morning and the guy was a complete duck egg! he didn't know what part it was as there were so many different choices.
if someone knows the part no i'd be very great full. a photo of what it should look like would also be welcomed.
cheers
Albatross
#1
The bottom small mouse sized part of the aerial (the bit I assume that is still there) on the roof at the rear is your sat nav. The short stubby bit (about 8cm) which is a rubberised mast is for your phone.
Your radio aerial is in the rear window.
BTW: Update your profile with the year, engine size and trim level of your car; it will save you from repeating yoruself and people from having to ask you or guess. You can put your location down to which will allow more local people to offer help too.
jonna
thanks Albatross, would you know what's meant to be inside the rubberised mast as i have a 4/5 cm piece of metal stuck there which seems to swivel around. also, any advice on the radio reception as it's crap?
Bumbazor
My radio reception is ok but as said before the aerial is in the rear window. Consequently, incredibly harsh interference occurs when I put the heated rear window on, which plays havoc with even the strongest signals.
I'll soon be exploring the possibilities of an additional (replacement) aerial to get round this problem.
Maybe your poor reception problem is similar, or might be cured similarly. Just a thought.
I'd be interested to hear of anyone else who has fixed the heated window/poor radio reception problem with an additional aerial. I could use a motorised aerial that is activated with the amp remote from my headunit... anyone done similar?
zirk
Is it an Estate ? (thinking ahead), post some pics of what you have.
Not on an estate, it's on the roof, different design base with a whip antenna that's hinged because the tailgate spoiler hits it when you open it!
Heater element antenna is on the saloon.
jonna
it is an estate. i can post some photos tomorrow!
ngrainqey
(not trying to hyjack your thread) my saloon hasnt got an ariel on the rear window... how can i have one put on/attach one with it being a heated window?
thanks
V8!!!!
Quote(not trying to hyjack your thread) my saloon hasnt got an ariel on the rear window... how can i have one put on/attach one with it being a heated window?
thanks
If you have a saloon your aerial IS in the rear screen, there's an amplifier somewhere near the rear parcel shelf for it.
I think this is what you wanted to do jonna!  ;)  :y
ngrainqey
thanks
ooo thanks andy :)
i'll have a nosey under the parcel shelf then!
V8!!!!
jonna
thanks andy, so now that the picture is up, does anyone have a clue as to the part i need or the piece that is missing?
is this silver piece correct?
Quotethanks andy, so now that the picture is up, does anyone have a clue as to the part i need or the piece that is missing?
Sorry what part is missing?
The picture above shows the ariel with GPS, that fat bit at the bottom is the GPS receiver.
Is it the top bit thats missing? Mother tunnies was damaged previously, its been repaired with a stiff metal pole in the base. Radio works fine.
The phone, it is built in and not an aftermarket jobbie? The Telematics unit should be in the glove box.
jonna
#14
tunnie, the sat nav is working fine but the radio isn't getting a good signal at all. i think it's just the top bit missing but not sure if the silver piece is the innards or weather it has just been stuck in! do you think that it's just the cover is missing?
can anyone show me a picture or tell me the part i need.
phone unit is in the glovebox!
cheers
