Author Topic: Alarm keeps going off  (Read 3595 times)
Martin_1962
« on: 08 October 2008, 21:55:42 »
Power sounder disconnected, bonnet switch disconnected, alarm has gone off twice tonight ::)
ngrainqey
  • rotherham
    • BMW E92, 2.6 CD F/L Est.
Re: Alarm keeps going off
« Reply #1 on: 08 October 2008, 22:02:12 »
if the power sounder batterys disconnected then shouldnt make a peep!
V8!!!!
Martin_1962
« Reply #2 on: 08 October 2008, 22:11:46 »
Horn and indicators go mad
MutantCav
  • Gainsborough
« Reply #3 on: 08 October 2008, 22:48:02 »
Dodgy boot switch?
« Reply #4 on: 08 October 2008, 23:03:27 »
Try turning off the motion sensor for a while ... I had problems with a reasonably large moth trapped inside, when it woke up and started flying around off went the alarm ... eventually found the bugger and removed him .. no further problems ..
Martin_1962
« Reply #5 on: 08 October 2008, 23:22:38 »
I'll try that if it goes off again :y
« Reply #6 on: 08 October 2008, 23:28:34 »
Check switch under bonnet or could be as Entwood says - large moth or small spider or fly!!
Dave DND
  • DND Services Ltd
    • Paignton, Devon
    • DND Services Ltd
« Reply #7 on: 08 October 2008, 23:39:15 »
I have known some other alarm systems to go off due to driving home with the heater on full whack and the cabin being nice and toasty, and when the alarm is set and the sensors take their readings, they can often see the sudden drop in temperature over the next hour or so as a detected fault. If this is the case, try turning down the sensitivity of the internal sensors a little.
Radio & Decoding Technician
www.dndservices.co.uk
« Reply #8 on: 09 October 2008, 08:52:48 »
anyone near you go a cheapo tech2 - should be able to tell why its going off...
Martin_1962
« Reply #9 on: 09 October 2008, 11:44:34 »
There is one at Brackley - when my cam covers are fixed!
« Reply #10 on: 09 October 2008, 11:52:01 »
Along with a Rad and condensor!
