Air bag light
Started by dave-b, 28 October 2008, 19:20:11
dave-b
Hi to all, new to this forum & I've a question already!
I'm about to aquire a '01 3.0 elite from a mate, but it has an airbag fault light that wont reset with Tech2. The fault comes up as 'child seat sensor' on the front passenger seat. Does anyone know if
a) the sensor is unplugged, will the light reset?
b) which is the plug (there are about six under there !)
c) is there any other way, other than replacing the sensor pad.
   (app. £300 from Vx !)
Not sure, as quite a rare option.
Wonder if MDTM or Kevin Wood can check their facelifts and see if its a variant code in SRS ECU?
It is a configurable option..........once only at first install!
QuoteIt is a configurable option..........once only at first install!
Like the side bags then?
Yep!
Looks like a piece of piss to bypass....its either a tie high or low job.
dave-b
QuoteLooks like a piece of piss to bypass....its either a tie high or low job.
I was hoping there would be a way around this............ would you care to elaborate !
Pin 39 on the airbag ECU needs connecting to either 12V or 0V(chassis), I would guess at 0V!
