Author Topic: alarm problems  (Read 4703 times)
spursyid
  • weston super mare
alarm problems
« on: 19 November 2008, 21:07:00 »
Hi ive got a 1999 3.0 elite,The other day all 3 nearside indercaters stayed on permantly,the only way i could get them off was to remove hazzard warning fuse,when fuse put back in all indercators were working,since then when car is locked only nearside indercaters flash and the battery drains if left for 24 hours,any ideas where to start please.
ghutchings
  • gerrards cross
    • omega elite estate
Re: alarm problems
« Reply #1 on: 05 October 2017, 19:51:23 »
have the same problem with a 2000 elite estate. to get the nearside indicators off i have to sit in the car use the key fob to lock the car, then put the key in the ignition and start the car.
this turns then off. occasionally they come back on when driving, its a real pain. if i bought a new alarm unit would it have to be coded to the car
Re: alarm problems
« Reply #2 on: 08 October 2017, 18:39:43 »
With all indicator faults on Omegas, press the hazard switch about 50 times in quick succession, then try again.
Beyond that, need to start pinning fault down, by, for eg, unplugging alarm unit.
  • Chatham, Kent
    • Ghastly 1.0l Focus
Re: alarm problems
« Reply #3 on: 08 October 2017, 19:42:29 »
With all indicator faults on Omegas Vauxhalls, press the hazard switch about 50 times in quick succession, then try again.
FTFY
ghutchings
  • gerrards cross
Re: alarm problems
« Reply #4 on: 01 November 2017, 19:05:47 »
fixed it ! ! !  see my post about grey relay
Re: alarm problems
« Reply #5 on: 01 November 2017, 20:52:12 »
Glad you're sorted ..... & a cheap fix too  :y
neil74
  • newport
    • 2.6 elite estate.
Re: alarm problems
« Reply #6 on: 02 November 2017, 23:13:26 »
I finally put the alarm horn back onto mine yesterday and to my surprise when I checked it it actually worked..
