Author Topic: Can You Replace a CCR600 With a CCR800...  (Read 2601 times)
MutantCav
  • Gainsborough
« on: 05 December 2008, 21:59:18 »
without having to upgrade the rest of the system, will the CCR800 work in standard mode, or will it send out a 2 Ohm signal and blow the standard speakers? Also would it need the Amp fitting or just straight swap the head units over and jobs a goodun??  ::)
Re: Can You Replace a CCR600 With a CCR800...
« Reply #1 on: 05 December 2008, 22:32:31 »
no, ccr800 has no amp.
MutantCav
  • Gainsborough
« Reply #2 on: 05 December 2008, 22:43:48 »
Wont it have a Bose amp as CCR800 is a bose headunit?? So you could take out the CCR600 and just put a CCR800 in its place with no other changes needed?
« Last Edit: 05 December 2008, 22:45:32 by ShieldOfSteel »
« Reply #3 on: 05 December 2008, 22:57:10 »
ccr600 and ccr800 are identical, except ccr600 has amp built in, and thus needs to drive speakers (4ohm) directly.  ccr800 has no amp, thus needs to go through bose amp (has to be bose due to odd levels), and then on to 2ohm spekaers.
MutantCav
  • Gainsborough
« Reply #4 on: 05 December 2008, 22:59:43 »
So as a minimum to fit Bose from a CCR600 unit in place you would need CCR800 head unit...Bose door speakers...amp and loom from drivers footwell to run amp??
« Reply #5 on: 05 December 2008, 23:02:30 »
And shelf sub speakers and shelf (saloon) or sub unit (estate).  If facelift, loom from hu to kick panel
MutantCav
  • Gainsborough
« Reply #6 on: 05 December 2008, 23:03:45 »
But it would still work without the sub actually in place? Albeit obviously not quite as well??
« Reply #7 on: 05 December 2008, 23:06:05 »
Hmmm, possibly not, or at least not for long - I suspect the amp would shut down...
