Author Topic: climte control  (Read 1666 times)
curly
  • romford,essex,
climte control
« on: 07 December 2008, 18:57:20 »
hi,anybody had there heater/air con blower fan stop,climate all lights up,can set temp and all other settings apart from the blower fan working from 1-9,checked all fuses/relays ok,there seems to be some form of resistor fitted on fan assembly behind glove box??any answers greatly recived.thanks.
Re: climte control
« Reply #1 on: 08 December 2008, 09:15:43 »
There is an electronic speed control assembly which is inserted into the air duct behind the glove box.
Also check F33 top left of the cabin fuse box.
And whilst you are at it, check the scuttle at the rear right of the engine bay where the pollen filter is for water!
