heated seats
Started by matt-sboro, 27 November 2008, 21:05:15
alexandjen
Quotesorry, haven't got my schematics load on laptop, so can't check which fuses
No worries, cheers :)
Trade club card holder
Code scanner available
matt-sboro
mine is the mini facelift so its not a push switch
i did check the 2 fuses that match up with the pictures on the fuse box and they were both fine  :-?
matt-sboro
anything else to look at?
as said before the 2 fuses that collaborate with the heated seats are both fine  :-?
has no-one had this problem in the mini facelift before?
I have the same problem, discovered it yesterday when it was freeeeezing!!! ::)
The other thing I have wrong is that the map reading lights have packed up. The fuses, bulbs, courtesy and doors lights are all fine!
I know its a long shot but is it just coincidental? :-?
Steve
matt-sboro
now you say that - yes my map reading lights dont work either :-?
Also, is your EML coming on intermitantly?
Cos mine does, read the codes and it came up with 3 codes:-
135- Telltale (checklight) voltage low.
87- AC cutoff relay voltage low.
52- Telltale (checklight) voltage high.
I was advised to change the bulb in the EML to see if that made a difference but didn't get round to it! :-[
But I'm now wondering if its all connected?? :-?
Steve
matt-sboro
i have code 87 too - i have other codes to do with the maf but yes i have code 87
can anyone else shed anylight on this one please?
no heated front seats (no led on switches either)
no map reading lights
code 87 a/c cutoff relay voltage low
