heated seats
Started by matt-sboro, 27 November 2008, 21:05:15
matt-sboro
they used to work really well - then both stopped at the same time - no led on the switch for both.
i've checked the fues and its fine which would point to a relay but that would not explain why the led stopped working on the switches
matt-sboro
have i got a problem the omega community doesnt know the answer to?
matt-sboro
wow this really did get everyone!! :D
Danny
could be the actual switches themselves
any other stuff not working on the instrument panel?
ngrainqey
urm...
have you checked the connections between the loom and heated bench?
it's either that or relay...
i had the wiring and the buttons and without then bench the lights wouldnt work so maybe to do with the relay or the connections
V8!!!!
matt-sboro
no these are the only switches not working
where are the relays kept for the heated seats?
ngrainqey
Quoteno these are the only switches not working
under the actual bench afaik!
V8!!!!
Dave DND
Do you have any voltages at the switches?
Radio & Decoding Technician
www.dndservices.co.uk
Are you talking aout the FRONT seats? The rear seats, if heated, are powered via relays, but I'm sure there are no relays for the fronts.
matt-sboro
yes its the front seats - both switches do not illuminate when you spin the control from '0' to '1'-'5'
i havnt checked for voltages yet
nabsim
Do they light up if you hold the switch pressed in? Have had switches where they stop 'latching' in that gives similar results. If you hold the switch in does the seat start to warm up?
QuoteDo they light up if you hold the switch pressed in? Have had switches where they stop 'latching' in that gives similar results. If you hold the switch in does the seat start to warm up?
iirc, there are 2 fuses for the fronts - one thats wired to switches, and other than feeds the heating controller (and heater itself) in each seat?
alexandjen
Any idea where this is situated as my drivers seat heater has never worked, put it down to pad burning out but will check fuses if I can find them :y
Trade club card holder
Code scanner available
if its just 1 seat, most likely the pad - either fuse would knock both seats out.
sorry, haven't got my schematics load on laptop, so can't check which fuses
