MID
Started by benbrunt, 08 December 2008, 23:06:45
benbrunt
Anyone have a copy of the MID code list? I'm trying to diagnose why the computer functions won't move from outside temp and want to find out how the computer is set up.
Cheers in advance
<marquee>[img name=signat_img_resize]http://farm4.static.flickr.com/3208/3130811192_b672fbed66_m.jpg[/img]
Gas Guzzler, I love the stuff!
dont understand what you are after?
If its stuck on one function, check the stalk (MID) or stereo (GID/CID)
Assuming you dont have TID which only shows temp (and radio and time)
benbrunt
Quotedont understand what you are after?
It's the half sized MID for the CCRT, the buttons on the stalk seem to click as they should. I wondered if people had a list of what the numbers mean when you hold down 'S' and 'R' for five seconds together
Ah, if you get the 3 numbers up, then switches etc all OK
Numbers are firmware version, config code, and pulses per km
benbrunt
Ta, back to the drawing board on that one then. I'll have to wait for a tech 2 sesh at a meet in the near future to see what's happening with the display
benbrunt
Cheers, it was the config code list I was wondering about
Don't have a convenient list for that type, but post up your numbers, and I'll tell you its config :y
benbrunt
#7
Well that's the weird thing, it varies slightly, it always says 058 top left, sometimes it says 049 on the bottom left, then after a while it decreases to 048 then 047 and never goes any lower
Stumped :-?
Ahh, ccrt700 mid - yes that puts up 4 numbers iirc.  I think from memory its the top left thats config code - I'll look it up later :)
benbrunt
QuoteAhh, ccrt700 mid - yes that puts up 4 numbers iirc.  I think from memory its the top left thats config code - I'll look it up later :)
Cheers, are you on the payroll at VX?
If not you should be!
No I am not. Thankfully.
benbrunt
TB - did you get chance to look up the codes?
TIA
Ben
QuoteTB - did you get chance to look up the codes?
TIA
Ben
058 - 2.5l, auto, not MID mode, no HIDs, 225/55/16 tyres
That doesn't make much sense, as wheels imply Elite spec, so should have HIDs and be in MID mode (seeing as ccrt display only fitted in 1999).
benbrunt
TIA
Ben
Cheers for that, explains why it's not functioning correctly. At least I know exactly what I need to get it fixed, a quickie with a genuine tech 2. Ta for that
(It has HIDs and I've a feeling the previous owner had it changed to cover up a fault with the headlamp height adjuster)
