fitting self leveling suspension
Started by vauxfan2k, 17 December 2008, 17:59:43
vauxfan2k
I am about to fit this to my 1996 2.5 cdx.
The connector for the pump is there under the front wing and I have connected the pump,I have also run the pipes to the rear shocks and connected them up.
I need to get another sensor for the rear suspension as my donor one is siezed, but apart from all this is ther anything else I need to do to get it to work? eg. relay and/or fuse?
if so can someone please tell me the location for them.
thanks  :y
Steve
relay (same as high beam one) under steering wheel, and an associated fuse.  No idea what else.
vauxfan2k
all the fuse locations have fuses in them and the relay is already there aswell. all I need now is the working sensor (on its way soon) and I should be able to test it.
thanks  :y
