MID stalk reset faulty.
Started by zirk, 14 December 2008, 14:01:32
zirk
Noticed yesterday that my MID Reset on the Stalk has packed up for MPG, Speed etc. However it still works Stopwatch function?
Anyone got any pointers or wiring info before I start ripping things apart  :y
Added, Ive already re seated the MID connecters and Dash Clocks.
vauxfan2k
you need to hold it in for a few seconds bud, its not a single click like the stopwatch.
press and hold for about 2s, display will go --- which means current function reset
press and hold for another couple of secs, display goes *** which means all functions reset
Jay w
Quotepress and hold for about 2s, display will go --- which means current function reset
you mean i have been going through all the menus and resetting for nothing  >:( >:(
Assuming you have a MID or ccrt700 display, yes ;D
zirk
Thanks, but it will not reset, was working, you can hold it in, wriigle with it for about a minuite, nothing it wont reset. but works fine on stop watch. Thats whats throwing me, Im assuming its the same switch inside?
Ian_D
Didnt know about holding it again to reset all of em!   ;)
[move][size=12]
[color=#ff0000] LMF are utter rubbish - dont buy steering idlers from them! You've been warned![/color][/size]
[/move]
Ian_D
Yes, its the same switch! So that cant be faulty!   ::)
[move][size=12]
[/move]
Press and hold both S and R for about 3s, and post up the numbers, just in case anything odd there...
zirk
Cant do that the Reset button not working (did try it, just in case), starting to think the MID itself has gone t*ts up.
zirk
#10
Ok, sorted, a bit of switch cleaner on the MID conecters  :y
