Heated seats
Started by dave-b, 28 December 2008, 22:41:54
dave-b
Are there any common problems with heated (leather) seats causing them not to work? I've just got an '01 elite which seems to have led a sheltered life but none of the heated seats work, front or rear, & I'm sure no-ones even sat on the rears! All the switches illuminate, but I've not had chance to check for 12v or open circuit at the seat connection plugs yet. I assume there is a timer relay somewhere, do these give problems ?
kris9128
have you checked the connections under the seats. when i got mine the rear seats woudnt heat up. appeared sombody had removed the base at some time and didnt bother to reconnect them.
Ironingboard
QuoteAre there any common problems with heated (leather) seats causing them not to work? I've just got an '01 elite which seems to have led a sheltered life but none of the heated seats work, front or rear, & I'm sure no-ones even sat on the rears! All the switches illuminate, but I've not had chance to check for 12v or open circuit at the seat connection plugs yet. I assume there is a timer relay somewhere, do these give problems ?
The rear drivers side doesn't work on my one, think there's a connection problem internally with the heating element, but its a big job to remove the leather in order to change them. Heating elements are a common problem, think GM fitted cheap ones, internal connections crack or break when you don't use them for a while and crack when you do use them.
They work or they don't provided there connected up. No timer on them as far as I know, take a few mins to warm up. Front ones should have a temperature setting you can set on the dash. 3 is warm enough on my car, too scared to try 6 incase I cook something  ;D
bighed
Would there be a fuse between dash switch and actual seat?
Ian_D
QuoteWould there be a fuse between dash switch and actual seat?
I doubt it tbh, however ive never even been in a facelift Omega, so who am I to say  :P
[move][size=12]
[color=#ff0000] LMF are utter rubbish - dont buy steering idlers from them! You've been warned![/color][/size]
[/move]
bighed
Only reason I ask is that both front bum warmers on mine dont work but switch lights up. Maybe they are fubarred  :'(
Quote..... Maybe they are fubarred  :'(
Quite likely, although it's normally the driver's seat that fails whist leaving your passengers with a warm bum. :( You'll have to test for 12volts at the seat multiplug.  :y
2nddaniel
Andy B. Can you elaborate a little on your experiences with drivers heated seat failure. Mine doesn't work. Other seats do work. Fuses intact, looked under seat for a multiplug, but found a substation. More wires than the thing that attacked Superman3.
Weapons officer, prepare to fire.
I am prepared. I'm the weapons officer.
Quote from: 2nddaniel on 07 February 2016, 22:13:01
You have to bear in mind that the two heat mats ..... one for the lower back & t'other for you bum .... are wired in series so if one fails you lose both. I found mine (& the Senator's before it ) had a burnt out section. If you remove the seat .... they're bloody heavy & DON@T switch your ignition on without the seat in place if you don't want the air bag light to stay on, the plug is fairly obvious.
I can't now tell you which one it is ...... I'm sure others will be able to tell you ...... it was about 10 yrs since I fixed mine  ;)
minifreek
Think its the blue plug under the seat.... Absolutely NOT the yellow, thats the airbag/tensioner circuit...
D.I.L.L.I.G.A.F...
I'm sure chrisgixer did a guide. Certainly I remember taking the photos when we did his 2 (ones was an element fault, one was a controller fault (only found in FL))
