MID display...
Started by ngrainqey, 24 December 2008, 13:17:58
ngrainqey
which is the mid display and what functions does it have on it?
thanks
V8!!!!
Clock, Radio display (Date if turned off) Check etc.
Two versions IIRC, depends what colour plug you have on the back of it.
MID is the most common, has check control features too, washer fluid, lights, oil.
Top bit has fuel consumption, range, trip, timer, temps, also check control displays here, bottom bit is radio
ngrainqey
ooooh...
thank for the replies
i wont beable to have chance to check what plug it is until atleast the new year really.
im guessing its the same as whats on the prefacelift then?
thanks
V8!!!!
mini facelift and later - grey plug
pre mini facelift, yellow and black plugs
ngrainqey
thanks tb and everybody else!
you know how you were saying about the CID screens, do you have to have a different head unit aswell to use that?
tbh i dont know at all as im used to the prefacelift!
V8!!!!
Quotethanks tb and everybody else!
Need an NCDx series radio to drive the CID or GID.
Need CCRT series radio to drive the CCRT MID
Everything else, MID or TID, depending on spec of car
ngrainqey
well i think it's ccrt2006 atm with the 4 disc changer but i quite liked the look of somebodys black 3.2 executivey one from europe (cant find the posts in gallery unfortunatly) with the colour screen :P
V8!!!!
Quotewell i think it's ccrt2006 atm with the 4 disc changer but i quite liked the look of somebodys black 3.2 executivey one from europe (cant find the posts in gallery unfortunatly) with the colour screen :P
NCDC201x plus CID, plus possibly a bit of minor wiring (depending on age).
Remember the NCDx series radios are not security coded like older radios, their theft protection is based on 'pairing'. The NCDC201x, cd changer (even though in head unit, is a seperate device), screen, and telematics (ncdc2015) are all coded together. If parts are removed without being depaired, they cannot be reused with 'new' devices.  I'll pop up a post in a few days explaining the NCDx series security a little better.
ngrainqey
V8!!!!
MutantCav
Its a 51 plate Alex is wanting to put it in...
