Author Topic: interior light delay  (Read 3998 times)
vauxfan2k
  • Western Isles
« on: 04 January 2009, 19:48:04 »
Jumped into the M reg v6 after it sitting for a couple of weeks, when I shut the door with the ignition on the interior light stayed on for the delay period that it should when the ignition is off.
Am I right in thinking that its the light itself that is at fault? as i dont have a spare one from this age of car, only the newer style.
cheers
Re: interior light delay
« Reply #1 on: 04 January 2009, 20:26:34 »
On my facelift the delay period is the same whether ignition on or off :-?
benbrunt
  • Oldham
« Reply #2 on: 05 January 2009, 20:40:55 »
My mini facelift switches the light off immediately if the ignition is on, sounds like either the timer delay system is fubard or one of the door switch has gone belly up.
Does the alarm allow you to deadlock all the time after you exit the vehicle, if it's a bit temperamental it could indicate that the door switch is sticking open?
<marquee>[img name=signat_img_resize]http://farm4.static.flickr.com/3208/3130811192_b672fbed66_m.jpg[/img]
Gas Guzzler, I love the stuff!
« Reply #3 on: 05 January 2009, 20:46:19 »
My mini facelift switches the light off immediately if the ignition is on,  .....
Likewise, as were the Senators & Carlton beforehand. And our 2 Astra G's  :y
« Last Edit: 05 January 2009, 20:47:07 by Andy_B »
vauxfan2k
  • Western Isles
« Reply #4 on: 05 January 2009, 21:02:08 »
this is how all my other omegas behave, so thinking light unit or door pin as you suggest, Ill investigate in the daylight
cheers
« Reply #5 on: 05 January 2009, 21:04:14 »
you done hillpers boot mod ;)
« Reply #6 on: 05 January 2009, 21:13:37 »
Yup ;D ;D
« Reply #7 on: 05 January 2009, 21:16:50 »
Yup ;D ;D
which explains your delay issue ;)
« Reply #8 on: 05 January 2009, 21:20:58 »
Yup ;D ;D
Oh, That`s why it stays on  ::) ::) ::) ;D ;D ;)
« Reply #9 on: 05 January 2009, 21:21:01 »
I have in mind an alternative with a relay.....this would sort it all out and with the addition of a few components would make it based on vehicle speed and not keys in!
benbrunt
  • Oldham
« Reply #10 on: 05 January 2009, 21:21:14 »
Yup ;D ;D
Doesn't that confuse the system so you can open the boot with the ignition running, hence the timer not realising that the ignition is on as the wire is disconnected / cut
« Reply #11 on: 05 January 2009, 21:23:13 »
The probelm with the hillper boot mod is that it fools the central locking ECu (which also controls the interior light!) into thinking the keys are always out the ignition!
The best solution in such setups is to tak the ECU output and the boot release switch signal and combine them (diode OR) into a relay ......
« Reply #12 on: 05 January 2009, 21:23:21 »
Yup ;D ;D
Rather have a confused light than prat about taking keys out just to open the boot :) :)
