Author Topic: How much...???  £217.10... Thats how much! lo  (Read 2679 times)
PaulW
  • Somewhere near Manchester
  • Come on you fiend!
    • Some crappy Insignia
« on: 11 February 2008, 20:10:18 »
Need prices for the following if ya can...
I can't find my TC login details for the web, so duno what/if these are available on the TC...
For X25XE (1998)
Plug leads
N/S Rocker covers gaskets & sealant etc...
Header tank bottle (with level sensor)
Plugs & Antifreeze are in the Red book anyways so I've got the price on those...
Cheers :)
« Last Edit: 12 February 2008, 15:06:06 by PaulW »
Humbugs...
MutantCav
  • Gainsborough
Re: How much...???
« Reply #1 on: 11 February 2008, 20:20:19 »
They need to be new??? I can do you a set of v6 leads from a 3.0 elite and a header bottle with sensor...
Jay w
  • Plymouth/Poole
  • omega gone
Re: How much...???
« Reply #2 on: 11 February 2008, 20:20:44 »
rocker cover gaskets are not on TC, i paid £62 for mine last weekend, that was the lot, sealant and 16 o rings
coolant bottle wont be on there either
plug leads i am not sure of
Darth Loo-knee
  • Death Star
  • Jammie smells of Pooh....
    • TIE Fighter
Re: How much...???
« Reply #3 on: 11 February 2008, 20:24:27 »
For X25XE (1998)
Plug leads
Cheers :)
From Vauxhall, Cam Gaskets, O rings, Cam Gasket Sealer £73
Plug Leads are stupid money about £200 when I asked :o
PaulW
Re: How much...???
« Reply #4 on: 11 February 2008, 20:25:32 »
Ideally would prefer new, just so to eliminate any further problems...
Well I only need 1 banks worth of gaskets, so guessing will be around £35 then.  Think I read once bottles are about 30-odd quid or so...  Leads... a kidney...
Humbugs...
Darth Loo-knee
  • Death Star
    • TIE Fighter
Re: How much...???
« Reply #5 on: 11 February 2008, 20:39:55 »
I had my Leads off M tec Perfomance
http://www.omegaowners.com/forum/YaBB.pl?num=1161455496
Good leads at around half the price of Vauxhall :y
Why are you only doing one side? surely while you have Plenum off it would be as well doing both sides?
« Last Edit: 11 February 2008, 20:41:14 by Loo-knee »
Re: How much...???
« Reply #6 on: 11 February 2008, 20:43:04 »
Get some Bosch leads off Ebay, they will cost about £30ish :y
PaulW
Re: How much...???
« Reply #7 on: 11 February 2008, 20:47:16 »
Will take too long to transfer stuff over to paypal & pay for & deliver...  need em all for the little gathering on the 23rd!
Gona see if sorting out these jobs first solves the other issues out...
Coolant loss I'm putting to a cracked headertank around the cap
Performance to the leads/plug wells being filled with oil
Just the rear multiram which I need to diagnose now...
Humbugs...
Darth Loo-knee
  • Death Star
    • TIE Fighter
Re: How much...???
« Reply #8 on: 11 February 2008, 20:50:06 »
Have found that if rear multiram isn't working either you have an air pipe leaking or the connection was broken on I guys i looked at..
PaulW
Re: How much...???
« Reply #9 on: 11 February 2008, 20:52:30 »
already checked over the piping of it, thats all fine and appears to be no leaks (checked all rubber unions, and pipes all over the system) its just the rear which isnt switching at 4krpm as it should...  And I don't have a voltage tester to see if the connection is actually triggering at 4krpm as it should...
Humbugs...
Darth Loo-knee
  • Death Star
    • TIE Fighter
Re: How much...???
« Reply #10 on: 11 February 2008, 21:19:00 »
At around 1000rpm the back multi ram moves, at around 4000rpm the front multi ram moves..  :y
PaulW
Re: How much...???
« Reply #11 on: 11 February 2008, 21:22:32 »
4/1/1/4....
well all I know is the rear dont do jack lol!
I'll check it over again tomorrow tho, but doubt it will make any difference...
Humbugs...
Darth Loo-knee
  • Death Star
    • TIE Fighter
Re: How much...???
« Reply #12 on: 11 February 2008, 21:39:12 »
The rear one should move when you blip the throttle to around 1000rpm, check all the air pipes, also I had to change the thing with the connector plugs into (cant remember what its called) because the connections had broken :y
Darth Loo-knee
  • Death Star
    • TIE Fighter
Re: How much...???
« Reply #13 on: 11 February 2008, 21:41:10 »
Have a look at this thread, just to check you have the air pipes in the correct places :y
http://www.omegaowners.com/forum/YaBB.pl?num=1152565204
PaulW
Re: How much...???
« Reply #14 on: 12 February 2008, 15:01:57 »
Yeah I've gone through that guide a few times, its all plumbed up properly so can't quite reason why its being a gimp!  I'll leave it for now anyways until the cambelt party :)
Well, just got the stuff...
V0090511451      Seal      x1 @ 27.25
V0090411826      O-Ring      x8 @ 0.15
V0093165267      Sealing Compound      x1 @ 8.00
V0009195109      Spark Plug      x6 @ 1.98
V0093165088      Antifreeze      1 @ 34.56
V0090494714      Set-Ignition Cables      1 @ 96.00
V0090500223      Tank, Header-Radiator      1 @ 25.65
Came to £217.10 all together so not too bad :)
Humbugs...
