Author Topic: Does any know where the wiring diagram is  (Read 4784 times)
Darth Loo-knee
  • Death Star
  • Jammie smells of Pooh....
    • TIE Fighter
« on: 14 February 2009, 17:17:03 »
For fitting Electric Seats into a car that has no electric seats, I was sure I had the diagram off the forum as I have done this wiring before, Just cant remember...
I have scrolled through a few hundred posts twice think I may have missed it. :-?
Cheers
Daz
Darth Loo-knee
  • Death Star
    • TIE Fighter
Re: Does any know where the wiring diagram is
« Reply #2 on: 14 February 2009, 20:50:20 »
Cheers for that Jaime, but the one I was talking about we had last year said connect black wire to green wire etc... thought it was off here, it could have been off "The Master" though :)
« Reply #3 on: 14 February 2009, 21:02:40 »
Connect the 0v (brown from memory, 2 of them) wires to brown, and the 12v (red from memory, again 2) wires to the permenent 12v presented in the car (also red iirc)
Darth Loo-knee
  • Death Star
    • TIE Fighter
« Reply #4 on: 14 February 2009, 21:11:33 »
Cheers TB ;)
I remember do it on Pete's Dad's car, but there was a wire wrong on the paper, which caused me to smoke a couple of fags ;D
« Last Edit: 14 February 2009, 21:11:54 by Loo-knee »
« Reply #5 on: 14 February 2009, 21:12:53 »
Cheers TB ;)
I've heard you like to be around fags
philiggy
  • oop north
« Reply #6 on: 14 February 2009, 21:14:00 »
So if I connect the browns to browns and reds to reds will it'll all work?
what happen with the air bags and seat heaters ?
Phil
« Reply #7 on: 14 February 2009, 21:17:12 »
Phil
They also need connecting, but the plugs should match for those.
philiggy
  • oop north
« Reply #8 on: 14 February 2009, 21:38:16 »
Phil
I'm not sure there will be plugs in the car for anything as its only got electric height adjustment, no airbags heaters etc. but the seats have elec everything,
 so if I just connect all the reds and browns will the heaters be on and the airbags triggers :o
Phil
« Reply #9 on: 14 February 2009, 21:51:59 »
Phil
Phil
Right, you have a problem.
If your car doesn't have side airbags, then it will have the older style seat belt pretensioners.  If the replacement seats have side airbags, they will have new style pretensioners.
Not sure there is a solution to that.
omegadti
  • Glasgow
    • omega dti
« Reply #10 on: 15 February 2009, 11:39:27 »
it is much simpler than you all think - under the seat there is a control box - there is a long plug with loads of wires at one end - the next plug to it is the power plug and there are two thicker cables - red live and brown earth, there are also some thinner cables which need connecting to live and earth - I have downloaded a photo of the box and connections (I am sure from this site) and I will send it to anyone who pm's me their e-mail address.  I was struggling for ages and no-one on the site actually identified which wires to connect - after finding this photo it took me five minutes to get a working memory seat!
« Reply #11 on: 15 February 2009, 12:03:05 »
The wiring diag has all you need.
Trouble is in this case it sounds like its the wrong seat :(
philiggy
  • oop north
« Reply #12 on: 15 February 2009, 12:07:59 »
I've just had a look, couldn't I take the seat tops off the runners and put them on the origional runners  :question
Phil
« Last Edit: 15 February 2009, 12:25:48 by philiggy »
« Reply #13 on: 15 February 2009, 12:26:34 »
Phil
Wrong pretensioners, not sure what to do.  Possible to swap pretenioners over??
« Reply #14 on: 15 February 2009, 12:34:59 »
Won't help OP, but just been given another wiring pic
http://images.omegaowners.com/documents/seats/elite_seat.pdf
Thanks to vauxfan2k :y
