Author Topic: cruise control  (Read 7290 times)
kjf7
  • lincolnshire
cruise control
« on: 16 February 2009, 20:54:59 »
bloody things not working checked fuses they're fine what do u think?
Re: cruise control
« Reply #1 on: 16 February 2009, 21:04:45 »
anything changes since it was working?
kjf7
  • lincolnshire
Re: cruise control
« Reply #2 on: 17 February 2009, 08:49:14 »
did'nt work when i got it!
Re: cruise control
« Reply #3 on: 17 February 2009, 18:22:46 »
Ahhhh!
Pop the top of the cowling off, find the little flying lead from stalk, and tell me how many wires it has...
kjf7
  • lincolnshire
Re: cruise control
« Reply #4 on: 18 February 2009, 00:07:24 »
sorry whats the cowling thing!
Re: cruise control
« Reply #5 on: 18 February 2009, 00:14:20 »
Plastic shroud around steering column, where your wipers and indicators stalks stick out from ;)
hotel21
  • The Kingdom of Fife
Re: cruise control
« Reply #6 on: 18 February 2009, 00:15:02 »
Its the plastic upper cover to the steering column, the bit to the top between the indicator and wiper stalks.  Three screws holding it in place from beneath as well as a couple staring you in the face when you rotate the steering wheel to quarter turn right/left, beneath the plastic balnking plugs.  Remove the screws, remove the shroud, and count the wires as TheBoy suggested then post back.....   :y
kjf7
  • lincolnshire
Re: cruise control
« Reply #7 on: 18 February 2009, 00:20:23 »
cheers will do that tomorrow as it's very dark at the mo [smiley=dankk2.gif]
kjf7
  • lincolnshire
Re: cruise control
« Reply #8 on: 22 February 2009, 16:44:22 »
ok only just got around to check how many wires and there's 2 a blue one and a whitey grey one both were broken so i've reattached and its working apart from the decrease speed button any ideas and thanks for you're help :y
Onkel Per
  • Frederikshavn - Denmark
Re: cruise control
« Reply #9 on: 22 February 2009, 17:46:02 »
From what I know, there should be four (4) wires.
Gray - Red - Blue - Green.
Re: cruise control
« Reply #10 on: 23 February 2009, 07:39:17 »
No, only 2 wires on the 2.5 diesel cruise stalk - all other Omegas are 4 wires.
Re: cruise control
« Reply #11 on: 23 February 2009, 07:40:26 »
Does the 'resume' function work (same button) - seem to recall the 'decrease speed' function isn't that good on the TD
MickAP
  • South Derbyshire
Re: cruise control
« Reply #12 on: 27 February 2009, 21:57:53 »
Fitted CC recently on mine. In the owners manual it says the decrease speed button is inoperative on the TD, the increase speed button does work.
Mick
« Last Edit: 27 February 2009, 21:59:37 by MickAP »
kjf7
  • lincolnshire
Re: cruise control
« Reply #13 on: 28 February 2009, 17:14:21 »
yes you,re right bloody cheap skates! does that mean the resume function does,nt work either and thanks :y
Agemo
  • Cleethorpes
  • Insignia
Re: cruise control
« Reply #14 on: 28 February 2009, 18:31:26 »
My descrease button has never worked, never knew it was inop on the Weasels! Oh and the resume DOES work on mine.  ::)
