Author Topic: Cruise Control  (Read 5451 times)
johnnycboy
  • Colchester
Cruise Control
« on: 04 March 2009, 18:14:01 »
Sorry lads/lasses
Have searched but unable to come to a conclusion.  On the 2.5 cd I have it's got all the bits and pieces in place (switch, actuator blah blah), but the Basteward thing don't work.  I have checked the basics such as fuses, can't seem to locate K14 though (I am assuming this is for DBW only or am I mistaken).  Anyway any help would be appreciated as I know you guys will.
Perhaps one day I may be able to give a little more back.  But I'm still learning from you guys/girls.
Thanks
Re: Cruise Control
« Reply #1 on: 05 March 2009, 08:20:17 »
Easiest diag method is to tech2 it!
I assume the brake switch is the correct type (4 pin) and the clutch switch is fitted (if appropriate)?
johnnycboy
  • Colchester
Re: Cruise Control
« Reply #2 on: 05 March 2009, 09:05:08 »
This I will check today - I'l post up later to confirm.  Clutch switch is that fitted for manual only.  Mines the 2.5 auto.
Cheers Mark
Re: Cruise Control
« Reply #3 on: 05 March 2009, 09:12:24 »
Yes, manual only.
Often the standard brake switch is just 2 wire and needs changing (you can short the 2 cruise wires out to prove this and as a workround)
johnnycboy
  • Colchester
Re: Cruise Control
« Reply #4 on: 05 March 2009, 10:27:26 »
Yes, manual only.
Have checked brake switch, you were spot on Mark - standard 2 pin. Have jumpered this for now :y.  If this is not changed what would be the consequences/implications in the future :exclamation.  The cruise function works as it should, releases when brake pedal pushed :y. Obviously there is a reason for 4 pins just wondered what the 2 pins do which have been jumpered.
Cheers
« Last Edit: 05 March 2009, 10:37:32 by johnnycboy »
Re: Cruise Control
« Reply #5 on: 05 March 2009, 10:51:55 »
There is no great reason for the extra pins on an auto as the autobox detects the brake being pressed by the existing brake lights setup and disables the cruise itself......different on a manual though!
johnnycboy
  • Colchester
Re: Cruise Control
« Reply #6 on: 05 March 2009, 11:07:46 »
Much appreciated Mark.  Think I will leave it as it is then 8-).
dad1uk
  • Birmingham
    • Vauxhall Zafira 2.2
Re: Cruise Control
« Reply #7 on: 05 March 2009, 21:01:56 »
I've just fitted cruise control, and wouldn't recomend not putting the correct switch on the brake pedal. It means if you hit the brakes in an emergency, the cruise control would NOT disengage.
To be honest, it wouldn't cost that much to buy a 4 pole switch.
best wishes
Simon.
    • E250 Est / Elroq
Re: Cruise Control
« Reply #8 on: 05 March 2009, 21:36:30 »
It WILL disengage on an auto  :y
johnnycboy
  • Colchester
Re: Cruise Control
« Reply #9 on: 05 March 2009, 21:49:13 »
It certainly does disengage, tried and tested :y
Re: Cruise Control
« Reply #10 on: 06 March 2009, 08:25:31 »
Yep, on an auto the auto box ECU can also disengage cruise control.
And the auto ECU also looks for the pressing of the brake pedal via the standard brake lights contact (as used on all cars anyway).
The Auto ECU, when seeing the brake pedal pressed, signals to the cruise off via its own input.
So, its only really essential for manuals!  :y
Beware though as it would appear that if you bugger with the brake switch and get it wrong then you can lock the brakes on (cant you Jimbob!) and that results in all sorts of screaching and grief  ;D ;D ;D
    • E250 Est / Elroq
Re: Cruise Control
« Reply #11 on: 06 March 2009, 08:35:13 »
Yes, but not from the car for some reason  ;D
    • E250 Est / Elroq
Re: Cruise Control
« Reply #12 on: 06 March 2009, 08:41:00 »
Should add the bugger still doesnt work though....
Actuator all fitted and wired in.
Clutch Switch Added
4 pin brake switch added
Stalk replaced
Cruise ECU responds and reports no faults.
Can't get any live data out of it yet though (yet  ::) )
Any other normal points of issue?
vauxfan2k
  • Western Isles
Re: Cruise Control
« Reply #13 on: 06 March 2009, 13:27:19 »
cruise only works from 30mph + and if you have your foot resting on the clutch or bake pedal at all it will open the circuit for the pedal switch.
Try shorting out the connector for the clutch pedal with a paper clip to see if that makes any difference.
Re: Cruise Control
« Reply #14 on: 06 March 2009, 13:31:50 »
Clutch Switch Added
Stalk replaced
Bugger, you asked me to check Live Data as well.  I'll do that later when I go out to car :)
