Siemens ncdc 2013 wiring connector
Started by HI2DVY, 04 May 2009, 11:45:41
HI2DVY
Hi,
I have a NCDC 2013 in my Elite and want to move the Parrot Bluetooth kit from my CDX. When I installed the Parrot in the CDX I used the mute and audio inputs which are normally used by the Trafficmaster system.
Before I pull out the NCDC2013 from the Elite it would be useful to know whether these inputs can still be used on this model - do they exists or are they used for something else? Alternatively, is there a better way of connecting my phone into the NCDC?
Thanks in advance.
Dave.
some day.....
I think you can buy an adaptor that plugs in the pre-wiring for the Parrot kit, if not you'll need to invest in something like an SOT-78 adaptor cable (and try and fit it behind the head unit!)
http://www.lowcostcaraudio.co.uk/lcca/88888/mia/d/autoleads+sot+078+vauxhall+sot+loom/pid/9404439
audio in and mute are on back. If you have Traffic Master, you will need to fix the Vauxhall half-arsed attempt at making a working loom.
Quoteaudio in and mute are on back. If you have Traffic Master, you will need to fix the Vauxhall half-arsed attempt at making a working loom.
And if you need a couple of the missing pins I have some here  :y
HI2DVY
Thanks TB and VXL. Just needed to know the pins are there and not used by satnav or something.
some day.....
QuoteThanks TB and VXL. Just needed to know the pins are there and not used by satnav or something.
The pins are most definately on the back of HU.  If you have external telematics, Trafficmaster, that will also use them, but Traffic Master does have a passthrough facility in the unit, but GM cocked up the wiring in the short TM loom
