Author Topic: no reverse lights  (Read 5557 times)
nick v6
  • walsall / west midlands
no reverse lights
« on: 25 May 2009, 13:31:05 »
just been told ive got no reseverse lights on the mig
does anyone know which fuse is it for the reverse lights
i'm hoping its either a bulb or fuse
Re: no reverse lights
« Reply #1 on: 25 May 2009, 13:53:31 »
Fuse 15, according to Mr Haynes, which also covers glove box, automatic level control system, Cruise control, sunroof, dash illumination, head light range adjustment.  :y
nick v6
« Reply #2 on: 25 May 2009, 14:00:20 »
all those work so its looking like the switch
how easy is it to get to the switch :-/
« Reply #3 on: 25 May 2009, 14:09:32 »
It is of course possible that its both bulbs blown.
Also, do rear fogs work? If not, look around earthing of bootlid
« Reply #4 on: 25 May 2009, 14:15:16 »
Assuming it`s auto, get someone to check lights when in reverse, move selector lever forward and back slightly, if lights illuminate, selector switch needs adjustment.
Boracic
  • Dartford Kent
« Reply #5 on: 25 May 2009, 15:13:54 »
I had this on my old Omega, it was a broken wire in the loom going to the boot lid, the part that’s on the passenger side in clear view, and I seem to recall the fog light indicator came on when I selected reverse
    • E250 Est / Elroq
« Reply #6 on: 25 May 2009, 15:17:24 »
Easy solved.....Dont go backwards  ;D ;D
nick v6
« Reply #7 on: 25 May 2009, 15:50:42 »
its a manual gear box :y
nick v6
« Reply #8 on: 25 May 2009, 15:54:42 »
fog lights work ok and ive changed the bulbs for reverse and still nothing :-/
nick v6
« Reply #9 on: 25 May 2009, 15:55:04 »
how do i get off the drive ;D ;D
« Reply #10 on: 25 May 2009, 17:27:05 »
It's likely to be the switch then. No idea how easy it is to get to though ...... My Astra's is dead easy!  ;D
I would think it's just earths to the gearbox, so if you find the switch, remove the wire & touch it to earth, your reverse lights should come on!
« Reply #11 on: 25 May 2009, 17:33:32 »
Rear of box, above propshaft  :y
« Reply #12 on: 25 May 2009, 18:10:02 »
Don't tell Mrs TheBoy, but her little Rover has spent most of the later afternoon going sideways (until I shagged the brakes) ::)
nick v6
« Reply #13 on: 25 May 2009, 18:26:27 »
i bet that hurt :-X
 ;D ;D ;D ;D ;D
