Author Topic: the clock display on dashboard  (Read 2427 times)
berkin
« on: 13 June 2009, 13:27:16 »
Hi,
I have a problem with my clock and date on the car computer display. The buttons above the display won't response and the date is 01.01.1998, the clock is 00:00 all the time.
Does anyone know what the problem can be? Is it the buttons or any other important problem?
Cheers
Berkin
zirk
  • Epping Forest
    • 3.2 Manual Special Estate
Re: the clock display on dashboard
« Reply #1 on: 13 June 2009, 15:23:44 »
Hi,
Cheers
Berkin
Could be the Buttons or could be dirty contacts feeding the buttons above the display unit, either way you will need to take the Dash out and have a poke arround.
10 min to take the Dash out by the way.  :y
http://www.omegaowners.com/forum/YaBB.pl?num=1192573381
« Last Edit: 13 June 2009, 15:25:36 by zirk »
Dave DND
  • DND Services Ltd
    • Paignton, Devon
    • DND Services Ltd
« Reply #2 on: 13 June 2009, 16:55:13 »
Jammed button maybe?
Radio & Decoding Technician
www.dndservices.co.uk
« Reply #3 on: 13 June 2009, 18:09:46 »
I think I've only ever played with the button above the clock once, and that was to set the time for France. All other times the RDS has set the time & date for me.
« Reply #4 on: 13 June 2009, 18:56:38 »
rds setting not available on older mids
« Reply #5 on: 14 June 2009, 09:26:29 »
Ah! That'd explain it.
berkin
« Reply #6 on: 14 June 2009, 11:45:38 »
Thanks a lot guys ;D. I will check my unit. :y
Cheers
Berkin :)
berkin
« Reply #7 on: 14 June 2009, 11:50:46 »
By the way, if it is a stuck button or the problem is due to a button problem, is it also normal that the clock and the date is always the same and never change? :-?
Berkin
« Reply #8 on: 14 June 2009, 12:10:52 »
Is the fuel computer info (range, mpg etc) above the radio info line, or below it?
berkin
« Reply #9 on: 14 June 2009, 13:15:49 »
The computer info is above the radio info line.
I also activated the RDS as it says in the manual but that didn't adjust the clock and date.
« Reply #10 on: 14 June 2009, 14:37:18 »
OK, newer style mid.
Presumably the buttons are working correctly if you are able to set and unset rds.
I would now begin to suspect a faulty MID.
If you are based near me, I would try reprogramming the config on it.
