Author Topic: CDR 2005 & Boot release  (Read 2796 times)
« on: 17 July 2009, 19:36:16 »
Right CDR 2005 not working won't turn on changed fuse should I try fuse in the back of the stereo too?
Also boot release not working when the button is pressed inside works fine on the key mind you, any idea's?
    • E250 Est / Elroq
Re: CDR 2005 & Boot release
« Reply #1 on: 17 July 2009, 19:39:45 »
maybe something has come loose at the back of em?
« Reply #2 on: 17 July 2009, 19:45:52 »
Fair point actually  :)
« Reply #3 on: 18 July 2009, 10:28:41 »
boot release - what age is car, as it varies as to how it works between early and later facelifts
« Reply #4 on: 18 July 2009, 10:32:33 »
2002 '52' Key wasn't in the ignition when trying to open boot  :)
« Reply #5 on: 18 July 2009, 10:34:16 »
Also the fuse in the back of a CDR 2005 is it a 10amp?
« Last Edit: 18 July 2009, 10:35:06 by LSG_1 »
« Reply #6 on: 18 July 2009, 10:44:16 »
press and hold for 2s
« Reply #7 on: 18 July 2009, 10:44:44 »
That would be why  ;D cheers TB  :y
« Reply #8 on: 18 July 2009, 10:46:14 »
might be 5.  likely to be a physically smaller size fuse as well
« Reply #9 on: 18 July 2009, 10:46:54 »
can check fuse in a mo - got cdr2005 in kitchen, but on phone to my brother fixing his server  :-[
« Reply #10 on: 18 July 2009, 10:47:13 »
Ok mate cheers for that  :y
« Reply #11 on: 18 July 2009, 11:20:23 »
checked. 10A, normal size car one :y
Dave DND
  • DND Services Ltd
    • Paignton, Devon
    • DND Services Ltd
« Reply #12 on: 18 July 2009, 11:29:56 »
Beat me to it -
 standard size 10A red blade fuse
Radio & Decoding Technician
www.dndservices.co.uk
« Reply #13 on: 18 July 2009, 14:01:24 »
Thanks mate  :y
Agemo
  • Cleethorpes
  • Insignia
« Reply #14 on: 18 July 2009, 21:54:53 »
"Key wasn't in the ignition when trying to open boot"
You could always do the Hillper boot mod:-
http://www.omegaowners.com/forum/YaBB.pl?num=1155211091 :y
« Last Edit: 18 July 2009, 21:57:00 by Agemo »
