Headlight switch illumination not working- bulb ok
Started by rastiman, 05 July 2009, 15:29:52
rastiman
I've notice the headlight switch illumination is not working - I've taken the cluster out and replaced the bulb, but still no joy!
The filament on the bulbs looks fine, and have checked there is a circuit etc, but still no joy.
The contacts in the unit are clean, and the bulb contacts are set correctly so Im at a loss  :o
Has anyone else had this problem, and found a suitable solution please?
Just when I thought I'd got the old girl sorted!
Replaced since March 09: Cam cover gaskets, plugs, leads, DIS, front suspension arms, multiram switch AND a partridge in a pear tree!!!
Proz
Headlight switch illumination only works when ignition is on  :y
rastiman
Hi Proz
Thanks for the heads up, but the problem persists even with the engine running  :-[
Darkus Lordus
QuoteI've notice the headlight switch illumination is not working - I've taken the cluster out and replaced the bulb, but still no joy!
Yup I have this problem too on my Elite which is a pre-Facelift if that helps. I have tried different bulbs, had the unit out & cleaned contacts & still doesn't want to know. The lights in the fog switches & level & dash illumination dials work but the main switch just plainly refuses!
You're not the only one... ::)
rastiman
Good to know Im not going mad!!!  :D Mine did exactly the same (mini facelift) with the fog light switches etc being illuminated, and they have gone dark too!
Short of taking the whole unit apart (which I dont particularly want to do coz I doubt it will go back together again!) Im stumped!
rastiman
Can anyone help solve mine and Darkus Lordus puzzle please................  :-/
kevpuk
mmm, never realised that it lit up but guess it makes sense....
so my facelift Elite doesn't light up, nor the foglight switches or the sunroof - boo !
Must get round to looking at these, then !  ::)
Taff
Just fitted a new bulb (£2.84 from Vauxhall) and have the dim dial light and level light working but Off Side and Dipped still dark.
Can everyone tonight check to see if these do actually light up? :-)
mathewst
This is really strange.
One bulb should light up the whole unit.
The thing when one side is lit up and the other isn't seems like something is blocking the light rom inside.
Also one thing you can try if new bulb isnt lit when placef.
Rotate it a little more cause I believe polarity of the bulb can be an issue here
Darkus Lordus
hmm, I always thought that the induvidual switches had their own bulbs in them & the headlight switch bulb just illuminated the healight symbols above the switch.
Upon closer inspection, the fog light switches & the symbols for the adjuster dials are all illuminated but the main headlight switch & the symbols above it are not lit up.  :(
Lee A
Mine all lights up, its very dim though, you can only see it when its properly dark outside.
Darkus Lordus
I think I'll be taking a switch apart.....  :(
jonnycool
QuoteMine all lights up, its very dim though, you can only see it when its properly dark outside.
Mine too
Agemo
#13
Mine work OK, but I would change the switch, cheap enough off here, all our breakers are in a position to test them first, better than a gamble on ebay.
Darkus Lordus
hmm.  :y You have a point there.
Any offers anyone??  :)  Elite headlight switch with both fog switches, level adjustment & dial illuminations wheels.
Once I have a second known working one. then I can set to dissecting the old one!!!! [smiley=evil.gif]
