Author Topic: Sat Nav in Estate question  (Read 6534 times)
goonv6
« on: 26 August 2009, 19:25:47 »
I've just bought a Carin system and am going to fit it in an estate. Can anyone show me the location of the unit and where the GPS antenna fits please? (I know there is a fitting guide but I think that's for a saloon.
    • E250 Est / Elroq
Re: Sat Nav in Estate question
« Reply #1 on: 26 August 2009, 19:34:32 »
im sure the main unit is meant to go on the tunnel between the rear footwells.
« Reply #2 on: 26 August 2009, 19:50:07 »
It was on the earlier Mini Facelifts but on the later ones it was fixed to the roof close to the rear door.
Is the system you have from an estate or a saloon?
« Reply #3 on: 26 August 2009, 19:52:33 »
It depends on if its an early or late system. On the early on it had a sticky pad and sticks to the dash by the tax disc, on the later system it has a bracket and it fixes behind the dash close to the centre vents IIRC.
« Reply #4 on: 26 August 2009, 19:54:18 »
Elite Pete is correct on both counts.
1998 cars have unit on tunnel between rear footwells, 1999 have in in headlining, NSR corner
goonv6
« Reply #5 on: 26 August 2009, 19:56:22 »
Mine's a 1999.I'm not sure what it came from but I would appreciate some piccies if anyone's got them. I thought the main unit went in the glovebox
« Reply #6 on: 26 August 2009, 20:04:01 »
You can see the player on the tunnel between the seats
and if you look to the rear right you can just make out the player in the roof
goonv6
« Reply #7 on: 26 August 2009, 20:13:40 »
Fantastic. Mine is a later car so if the loom will allow,I'll mount in in the roof. I wonder is any one has the mounting pod.  8-) Thanks guys.
« Reply #8 on: 26 August 2009, 20:15:50 »
I think you might find it difficult to get hold of, it was only used for about 12 months or so and only on the estate so I would think it quite hard to find :(
goonv6
« Reply #9 on: 26 August 2009, 20:35:18 »
Reckon I could make that tunnel one. Looks a bit weird though!
« Reply #10 on: 26 August 2009, 20:38:22 »
It gets a good kicking from the kids as well ::)
« Reply #11 on: 26 August 2009, 21:27:27 »
Got a suspicion I have a dark grey tunnel mount somewhere, but can't think where on earth it is  :-[
goonv6
« Reply #12 on: 27 August 2009, 00:50:45 »
I could make it worth your while (he says in a completely unsuspicious way...)
Robin Hood
  • Nottingham
« Reply #13 on: 27 August 2009, 09:02:55 »
In mine (a ’98 estate) the unit was moved to the centre of the spare wheel and the cables ran under the back seat.  Very clean and practical.
« Reply #14 on: 27 August 2009, 14:07:16 »
You could have it if I could find it, but it wasn't where I expected it to be.  Wouldn't know where else to look for it, so guess I binned it  :-[
