Author Topic: Headlight switch woes .....  (Read 2342 times)
I_want_an_Omega
« on: 03 October 2009, 16:28:50 »
I dont know if the following are interconnected - so here goes:
I removed my headlight switch and since putting it back the twist action isn't very positive any more. Also, the interior light is now too easy to leave on - so I removed the bulb so that I wouldn't get a flat battery. Since remocing the bulb my alarm seems to be going off rather a lot - good job the powersounder isn't working.
Are these related, I suspect so.
Thanks
Welung666
Re: Headlight switch woes .....
« Reply #1 on: 03 October 2009, 22:00:12 »
What have you done? ;D ;D ;D
Did you use the knob to pull the switch out? If you did the small plastic clips that give the 'click' for the interior light could have snapped. I've got a headlight switch here if you're stuck, it's a non-HID switch with the leveller control.
rustym95
  • Rotherham south yorks
  • carn't get up dont go out!!
« Reply #2 on: 04 October 2009, 00:56:12 »
did you take it to bits, cos if you did you may not of set it back propely, i did mine and changed the led's in side and you have to put it back together right or it well not work properly, there is a pin for the intera light switch if not in, its not locked in place and can turn on the light on and off, it falls out when you open the unit. i put blue leds in side works well can see it all now. :y
« Reply #3 on: 04 October 2009, 17:25:25 »
i put blue leds in side  ......
Did you get permission from The Boy first????  ::) ;D
I_want_an_Omega
« Reply #4 on: 04 October 2009, 17:26:50 »
No, I didn't "pull the knob" to remove the switch, and TBH i'm more worried about the blooming alarm going off as a consequence of what I've done, I've just realised that I have spare headlight switch so might give that a try .....
Thanks anyway.
« Reply #5 on: 04 October 2009, 17:33:38 »
.... I've just realised that I have spare headlight switch so might give that a try .....
Thanks anyway.
Not that it probably makes any difference to what you're doing, but be aware that not all mainlight switches have the lights-on-buzzer built into it. Mine's a seperate buzzer down inn the passenger footwell/behind the glove box.  :y
(Jamie can tell you which cars have this arrangement  ::))
rustym95
« Reply #6 on: 08 October 2009, 23:35:41 »
no i did not had them in a year now changed all bulbs for leds bar for the head lights main and dip, use less battery power and more brighter than bulbs, did you ask the boy when you did your car up  :D ;D ;D
« Reply #7 on: 08 October 2009, 23:39:26 »
[ ......did you ask the boy when you did your car up  :D ;D ;D
No!  ;) I haven't done anything none standard to mine though  :y
Anyway The Boy has the monopoly on led's .... especially blue!  :y
rustym95
« Reply #8 on: 08 October 2009, 23:45:37 »
oh well i like it, to old to be a boy racer, just like my lights to be good, any way they are fasing out ordery bulbs so ive heard, make to meany cfc's to make the bulbs. :y
Page created in 0.158 seconds with 16 queries.
