traffic master loom for 2015
Started by feeutfo, 03 September 2009, 08:38:25
i have asked this before, both on here and personally asked Jamie. I think the answer was get any face lift radio loom (from ncdc i guess?) and add a couple of wires...?
I have a TM and button just need to connect it all up.
So question 1
Have i remembered correctly? is that all i need to connect a silver traffic master box to the head unit? Needs an aerial connection also i think?
Question 2
Does anyone have one, thats going to newent, so i can bother Jamie with it yet again  :-[  ;D
Standard 36 Way TM ISO loom but will require the mute and Audio in wiring through (get the required pins from www.nexxia.co.uk).
Aerial connection on the silver ones is a BNC plug with two solid core conductors spread out to make a dipole.
QuoteStandard 36 Way TM ISO loom but will require the mute and Audio in wiring through (get the required pins from www.nexxia.co.uk).
Hi Andy, thanks for reply, ihave a TM loom but its from a vectra of some sort and am lead to beleive thats no good? :-/ (as its for a vectra)
Won't be a 36 Way one then (are there three rows of pins on the top block???)
QuoteWon't be a 36 Way one then (are there three rows of pins on the top block???)
no, only 2 :'(
right, got a loom, and button. Thanks to Welung 666. Will be using silver box with aerial lead.
....these pins and wires i need to add. Or wires to existing pins or whatever, has anyone got the patients to explane it to me? Like i'm a 2 year old? Prety please?
Baring in mind i know about as much as a 2 year old when it comes to electrics. :-)
Quoteright, got a loom, and button. Thanks to Welung 666. Will be using silver box with aerial lead.
look at diags - the audio in (2 wires) and mute (1 wire, but not needed), need to go through tm box
Quote34 & 35 IIRC
sounds about right...
Quote34 & 35 IIRC
here?
http://www.nexxia.co.uk/More_Information/ISO_wiring.htm
That site is rubbish.  You have TIS don't you?
Quote34 & 35 IIRC
here?
Yeah, but last i looked it was fubar. Will check again.
Hang on.
Quote34 & 35 IIRC
here?
Hang on.
34 35 36 all show "phone/voice control"
3 options, which is which, all Egyptian to me, sorry guys  :-[
Just look at the connector that the car loom plugs into and see what pins are missing!
QuoteJust look at the connector that the car loom plugs into and see what pins are missing!
There as no missing pins on either the radio or car loom end of the tm loom. Each connecter is full of pins and all pins have wires on them.
