Author Topic: cant get sound out ov new cd player  (Read 4761 times)
v6_omega
  • south wales
« on: 10 November 2009, 15:53:09 »
just bought the v6 estate omega and bought kenwood flip to replace the phillips ccrt700 but cant get no sound out ov it all cums on but no sound output .... any help wud be much appreciated thanks
    • E250 Est / Elroq
Re: cant get sound out ov new cd player
« Reply #1 on: 10 November 2009, 15:57:58 »
does your ccrt700 have bose written on it?
and the speaker covers?
if so, there is an amp in the system as well, and speaker all run at 2 ohms, a lot of work to replace.
v6_omega
  • south wales
« Reply #2 on: 10 November 2009, 15:59:31 »
will a vauxhall cd player work in there then becoz the kind owner before me removed the disc changer from boot
    • E250 Est / Elroq
« Reply #3 on: 10 November 2009, 16:33:32 »
if you have a bose system, then only a bose system will work unless you replace everything.  :'(
v6_omega
  • south wales
« Reply #4 on: 10 November 2009, 17:01:39 »
cheers any chance u know where the leads r supposed to be for the disc changer  :)
    • E250 Est / Elroq
« Reply #5 on: 10 November 2009, 17:03:08 »
they should end in a cubby hole, drivers side corner by boot opening.
can I get you to avoid text speak as well please  :y  frowned upon here  :y
v6_omega
  • south wales
« Reply #6 on: 10 November 2009, 17:07:37 »
sorry i ll try and i know i sound dull but wot do the leads looklike and how can i get my ccrt700 decoded thanks  :y
    • E250 Est / Elroq
« Reply #7 on: 10 November 2009, 17:11:34 »
Dave DND on here can sort you out with the code.
should be a power lead and a multiplug loitering behind the cubbyhole.
v6_omega
  • south wales
« Reply #8 on: 10 November 2009, 17:18:37 »
i think i found them is the power lead got like a brass finish on it and do you know what changers were in the cars originally  :) thanks
    • E250 Est / Elroq
« Reply #9 on: 10 November 2009, 17:25:17 »
think its a blaupunct cdc-2, but a specific one, there are several types of cdc2
« Last Edit: 10 November 2009, 17:25:50 by jimbob »
Dave DND
  • DND Services Ltd
    • Paignton, Devon
    • DND Services Ltd
« Reply #10 on: 10 November 2009, 17:26:51 »
Yep !
CCRT700 codes are now available here
http://www.dndservices.co.uk/vauxhall-ccrt700-bose-on-star.html
Radio & Decoding Technician
I_want_an_Omega
« Reply #11 on: 10 November 2009, 18:07:06 »
Have you answered if it has Bose or not? Its quite important and will help us to help you!
The connector int the changer is actually a single one having 2 x 6 pins in a black moulded connector.
HTH ......... Rob
v6_omega
  • south wales
« Reply #12 on: 10 November 2009, 18:12:21 »
it is bose aand i think i found the wires but do any ov u know the sequence to input the radio code on the ccrt700 thanks for your help so far everyone much appreciated
Dave DND
  • DND Services Ltd
    • Paignton, Devon
    • DND Services Ltd
« Reply #13 on: 10 November 2009, 18:13:35 »
HTH ......... Rob
I`m making the assumption that if a CCRT700 was fitted, then yes, it would be BOSE ?
I_want_an_Omega
« Reply #14 on: 10 November 2009, 19:41:49 »
Only to Elite models, the non-Bose CCRT700 was also available on mini-facelift as an option
