Author Topic: Replacing drivers seat  (Read 6947 times)
MickAP
  • South Derbyshire
« on: 12 November 2009, 13:25:34 »
Ok put this in electrical as I need to know about the electric side of things on the drivers seat.
I need to replace the drivers seat on my 03 plate 2.2 CD. Would there be any issues with the airbag in the seat if I disconnect the electrics, or for that matter anthing else in there. Read on here that it's best to disconnect the battery to stop the airbag warning light coming on, then have to reset it.
I take it disconnecting the battery I will only have to put the code back into the radio when reconnecting, is that all?
Cheers
Mick
« Last Edit: 12 November 2009, 13:26:07 by MickAP »
    • E250 Est / Elroq
Re: Replacing drivers seat
« Reply #1 on: 12 November 2009, 13:31:46 »
if the battery is disconnected for the duration of the swap, then it should be fine.
then just radio to reset, and one touch open / close on windows.
Dave DND
  • DND Services Ltd
    • Paignton, Devon
    • DND Services Ltd
« Reply #2 on: 12 November 2009, 13:49:05 »
Remember to observe airbag precautions though !
After disconnecting battery - wait for 1 hour before unplugging the seat (or any other) airbag as this give the unit time to discharge
Once all back together there shouldn`t be any need to reset the airbag light providing the battery has been disconnected throughout the duration.
Radio & Decoding Technician
www.dndservices.co.uk
unlucky mark mv6
  • tipton,west mids
« Reply #3 on: 12 November 2009, 15:01:09 »
I thought it was 1 minute dave to wait for capacitors to discharge,but could be wrong. :y
Dave DND
  • DND Services Ltd
    • Paignton, Devon
    • DND Services Ltd
« Reply #4 on: 12 November 2009, 15:45:54 »
Er . . . No !!
1 minute and the airbags will probably deploy (all of them, not just the one you are working on)
Most handbooks advise 15~30 mins - my advice would be to make a cup of tea and wait one hour - better safe than sorry.
« Last Edit: 12 November 2009, 16:01:06 by Dave_DND »
MickAP
  • South Derbyshire
« Reply #5 on: 12 November 2009, 16:01:08 »
Er . . . No !!
Most handbooks advise 30 mins - my advice would be to make a cup of tea and wait one hour - better safe than sorry.
Cheers for that, will take your advice.
Mick
unlucky mark mv6
  • tipton,west mids
« Reply #6 on: 12 November 2009, 19:41:25 »
Er . . . No !!
We dont want then do we. :D
« Reply #7 on: 12 November 2009, 21:18:02 »
Er . . . No !!
Never have waited more than a couple of minutes after disconnecting to be honest, never had one go off  :)
« Reply #8 on: 12 November 2009, 21:25:07 »
Er . . . No !!
GM docs on this system state 1m - the components go into a 'safe' mode where they discharge themselves.
Call me a wimp, but I always go for cuppa after discon battery though ;D
Dave DND
  • DND Services Ltd
    • Paignton, Devon
    • DND Services Ltd
« Reply #9 on: 12 November 2009, 22:32:05 »
I`ve seen too many go off at various Audio installers who also thought that a few minutes was enough - And I felt for the guy who removed a headrest from a Volvo and tripped a total of 11 airbags and side curtains in doing so.
Whilst we are on the subject, it IS possible to remove an airbag and replace it with an appropriate value resistor in its place, but NEVER NEVER NEVER try to measure the resistance of a disconnected airbag with a multimeter to try and work it out, as it WILL trigger.
« Reply #10 on: 13 November 2009, 18:57:20 »
The ones that don't trigger (and not all do nowadays), give false readings anyway, as the component places a (almost) short across itself to discharge itself.  This seems to be the case for the Siemens ones that Vauxhall seem to prefer...
« Reply #11 on: 13 November 2009, 19:01:20 »
But Dave DND is right, unless you are 110% sure you fully understand the system, defo errr on the side of caution - if one deploys, your backside will chew through the gusset of your smalls.
Those that know me will know that even when running diags on cars, I always leave the car when interrogating airbag ecus with cheap code readers ::)
« Reply #12 on: 13 November 2009, 19:12:11 »
Wuss!  ::)  ::)  :y  :y  :y ;)
« Reply #13 on: 13 November 2009, 19:14:30 »
There speaks a man who:
a) has never chewed his pants up his backside
or
b) too daft to feel the aftermath
I'm hoping a) is the answer ;D
Dave DND
  • DND Services Ltd
    • Paignton, Devon
    • DND Services Ltd
« Reply #14 on: 13 November 2009, 19:52:35 »
or
 ;D ;D ;D ;D
Page created in 0.022 seconds with 20 queries.
