Author Topic: Indicator Failure  (Read 2894 times)
Neil (Cardiff)
  • Cardiff
Indicator Failure
« on: 22 November 2009, 16:32:12 »
Just took the car shopping to Asda and the indicators have packed up! Not a normal fault, they're totally dead, nothing at all. The hazards still work fine. I've tried taking the flasher unit out under the steering wheel and that stopped the hazards. Is there another one for the indicators or do they both use the same? Everything else on the stalk works (cruise control, main beam etc). Any ideas? I aint good with electrics! :y
Re: Indicator Failure
« Reply #1 on: 22 November 2009, 16:43:30 »
Turn the hazards on and off 30 times.
Neil (Cardiff)
  • Cardiff
« Reply #2 on: 22 November 2009, 16:51:54 »
Eh?
Welung666
« Reply #3 on: 22 November 2009, 17:00:21 »
There's a contact in the back of the hazard switch that sticks sometimes. Turn the hazards on and off 30 or so times then try the indicators ;)
Neil (Cardiff)
  • Cardiff
« Reply #4 on: 22 November 2009, 17:19:13 »
Wow thats amazing only on here would you get advice like that! Thanks people  :y Will give it a go now
Neil (Cardiff)
  • Cardiff
« Reply #5 on: 22 November 2009, 20:48:01 »
Fantastic! Cured. Thank you all  :y
« Reply #6 on: 22 November 2009, 20:56:33 »
May be a sign that switch is tired. If it does it again, may be worth a new switch :)
Ian_D
  • York
« Reply #7 on: 22 November 2009, 21:27:29 »
Well done mate!
Has to be the simplest fix of all time!  ;D :y
[size=12]
Page created in 0.219 seconds with 16 queries.
