Author Topic: Facelift 12v power socket  (Read 3745 times)
Omega3
  • Hertfordshire
« on: 23 November 2009, 19:50:33 »
Hi folks. Does anyone know if it is possible to change the amount of time that the rear 12v power socket in a facelift saloon stays on for, after the ignition is turned off. Mine currently turns off after approx 5 mins.
Cheers
Previously: Mercedes CLK 320cdi, Insignia SRi, 53 Omega 2.2CD, 02 3.2 elite, 01 Omega 2.2CD, 94 Omega 2.0 Est, Mercedes 300TE, Toyota Supra 3.0, Honda Legend Coupe, Supra 2.8i Mk2, Fiat X1/9, Lancia Trevi
Re: Facelift 12v power socket
« Reply #1 on: 23 November 2009, 20:27:16 »
Get a feeling its a hardware timer...
Weds
  • Chatham, Kent
  • My other hobby
    • Mercedes E class 350 CDi
« Reply #2 on: 24 November 2009, 06:19:38 »
Mine stays on all the time...
    • E250 Est / Elroq
« Reply #3 on: 24 November 2009, 07:09:23 »
does seem to be a problematic relay for these.
often a good port of call if you have battery drain issues.
cruisetopoland
  • UK
« Reply #4 on: 24 November 2009, 07:10:05 »
Cheers
Mine goes off when engine switched off  :y
I know this, as tontom powered from it and shuts down when switch off.
« Reply #5 on: 24 November 2009, 11:05:21 »
It's fed from a time delay relay. Not sure if you could get a relay with a different delay time. Quite possibly.
I believe other items are fed from this relay too (leccy windows, interior lighting, IIRC) so a longer delay might be problematic.
The accessory socket is fed from its' own relay which is, in turn, fed from the time delay relay so there is the potential to bridge the contacts on this relay to make it permanent, with the consequence that anything you leave connected by accident will flatten the battery.
Omega3
  • Hertfordshire
« Reply #6 on: 25 November 2009, 16:50:45 »
Thanks for the info guys. I was looking for something around 30 minutes on. Rather not permanent for reasons pointed out, I'm highly likely to forget and then be turning the air blue....  ;D
Just seen the modification for the wiper delay relay and wondering if the same thing is possible with the 12v socket relay.
Dave DND
  • DND Services Ltd
    • Paignton, Devon
    • DND Services Ltd
« Reply #7 on: 25 November 2009, 19:33:20 »
30 mins is long enough to flatten a battery if not carefull - what are you trying to run?
Radio & Decoding Technician
www.dndservices.co.uk
Omega3
  • Hertfordshire
« Reply #8 on: 25 November 2009, 21:34:48 »
Thanks dave. Just trying to power the ipod (aka gaypod here.. ;D ;D ;D)
Would just like it to stay on a bit longer before the power cuts off interupting the moment.... ::) ahem. (come to think about it maybe 30 mins is not enough... ;) )
Dave DND
  • DND Services Ltd
    • Paignton, Devon
    • DND Services Ltd
« Reply #9 on: 25 November 2009, 22:45:53 »
Erm . . . .
My iPod has a built in battery, and powers up when I press the ON button
 :P
Omega3
  • Hertfordshire
« Reply #10 on: 26 November 2009, 10:31:52 »
Erm . . . .
 :P
Sorry, didn't realise they had a built in battery. ;D Thought they had to have a car attached.
What I should have said was there's an FM transmitter (howls of derision) connected to the ipod which shuts down when the power cuts. I should probably have fitted a proper FM modulator as advised but took the easy (just about acceptable) route  ::)
