Pages: [1] 2 3  All   Go Down
Author Topic: bodging a wiper stalk  (Read 25084 times)
BigAl
  • Bromley, Kent
    • '07 Forester
« on: 30 October 2008, 23:41:45 »
Is it possible to retro-fit a pre-facelift(PFL) stalk with adjustable intermittent in-to a facelift(FL)?
Physically the only difference i can see is that the fly lead for the PFL has a 6-pin connector with 5 wired while the FL one has a 4-pin connector with 3 wired
Martin_1962
Re: bodging a wiper stalk
« Reply #1 on: 31 October 2008, 11:33:09 »
My Facelift has intermittant wipers :-?
tmx
  • Herefordshire
    • 3.2 MV6 2002
« Reply #2 on: 31 October 2008, 12:35:05 »
my collegues 06 Corsa C Van has intermittant wippers  ;D
Welung666
« Reply #3 on: 31 October 2008, 12:41:57 »
I think Al is after the variable speed option on the intermitents
BigAl
  • Bromley, Kent
    • '07 Forester
« Reply #4 on: 31 October 2008, 14:04:16 »
Yes, My new mig is missing the variable intermittant option, but has the standard intermittant setting
Mike Collins
  • North of Bristol
« Reply #5 on: 31 October 2008, 21:21:58 »
Yes it's possible, you have to arrange the variable resistor to be in series with the feed to the relay. If you have a wiring diagram you should be able to see the wire to interrupt.
I have, somewhere, some pictures of how I modified mine. I will try to find them tomorrow.
BigAl
  • Bromley, Kent
    • '07 Forester
« Reply #6 on: 31 October 2008, 21:45:01 »
Cheers Mike, Most appreciated
    • E250 Est / Elroq
« Reply #7 on: 31 October 2008, 21:50:31 »
erm a facelift cdx should have intermittant wipers!
unless...
Have you got rain sensors?  that would cause you not to have variable...
BigAl
  • Bromley, Kent
    • '07 Forester
« Reply #8 on: 31 October 2008, 22:10:20 »
I don't think i have rain sensors, what do they look like?
I assume i either don't have them  or they don't work as when on intermittant the speed does not change do matter how heavy the rainfall
alexandjen
  • Sittingbourne, Kent
  • The Silver Surfer
« Reply #9 on: 31 October 2008, 23:19:32 »
unless...
Mine hasn't, not variable anyway, and have been looking to carry out this mod for some time now ::)
« Last Edit: 31 October 2008, 23:20:22 by alexandjen »
Trade club card holder
Code scanner available
Mike Collins
  • North of Bristol
« Reply #10 on: 01 November 2008, 14:36:07 »
If you let me have an email address I can send you some pictures, my 03 CDX did not have variable delay or rain sensor, despite the salesman's words.
You will need a circuit diagram to identify the pin in the wiper main connector that needs to be removed, then the variable resistor is wired in series with it.
I have not yet changed the relay so have a slightly limited range of delay timing.
BigAl
  • Bromley, Kent
    • '07 Forester
« Reply #11 on: 01 November 2008, 14:49:48 »
PM sent
dpanic88
  • West Midlands
« Reply #12 on: 07 November 2008, 18:16:31 »
Pm sent, also after help on this
Hope you have the time to reply, regards
NickA
  • Cambridge
« Reply #13 on: 07 November 2008, 23:12:13 »
I added the variable wipers to my 02 mv6 as part of a Sat nav/Bose upgrade. All it needed was one of wires to the exisiting wiper stalk cutting and then re-connecting to extra pair of wires on the new variable stalk.
I'll see if I can find my notes on what needs connecting to what. Think is was one of the black/yellow cables.
BigAl
  • Bromley, Kent
    • '07 Forester
« Reply #14 on: 07 November 2008, 23:38:46 »
Cheers NickA, any help would be appreciated
Pages: [1] 2 3  All   Go Up
