Author Topic: 2.2 spark plug gap  (Read 12196 times)
cruisetopoland
  • UK
2.2 spark plug gap
« on: 28 January 2010, 11:55:10 »
Just about to have a go replacing the sparkers on my 2.2....need to gap the plugs first.
What is the recommended plug gap on NGK BKR6EK for the 2.2 16v, anyone?
Re: 2.2 spark plug gap
« Reply #1 on: 28 January 2010, 11:56:16 »
'gap' the plugs?  :-/
I just stick GM twin electrodes in, and wack the coil pack on top  :y
cruisetopoland
  • UK
« Reply #2 on: 28 January 2010, 12:00:47 »
These NGKs are twin electrodes...
I have always gapped plugs before putting them in...is it not necessary on the Omega?
    • E250 Est / Elroq
« Reply #3 on: 28 January 2010, 12:02:07 »
you do not gap multi electrode plugs, only single  :y
« Last Edit: 28 January 2010, 12:02:21 by jimbob »
cruisetopoland
  • UK
« Reply #4 on: 28 January 2010, 12:03:15 »
Just found it on page 229 of the handbook:
1.0mm +/- 0.1mm
Will crack on....in my suit...
cruisetopoland
  • UK
« Reply #5 on: 28 January 2010, 12:04:04 »
Many thanks-will just "drop" them in.
Surely something else with go wrong, they'll thread or something  :o
    • E250 Est / Elroq
« Reply #6 on: 28 January 2010, 12:07:15 »
lol, dont go too tight then  :y
25 nm  :y
unlucky mark mv6
  • tipton,west mids
« Reply #7 on: 28 January 2010, 12:19:19 »
Any plug you buy now should be already pre set. ;)
cruisetopoland
  • UK
« Reply #8 on: 28 January 2010, 12:25:13 »
25 nm  :y
 :-? Does that mean don't hammer the handle of the socket set round with a mallet?
Look into my eyes, not around the eyes.....you will call a competent mechanic in order not to cause horrific damage.....back in the room  :o
cruisetopoland
  • UK
« Reply #9 on: 28 January 2010, 12:25:58 »
Give me a 2CV to work on, any day  ;D
unlucky mark mv6
  • tipton,west mids
« Reply #10 on: 28 January 2010, 12:43:56 »
And ill have a pushbike. :D
cruisetopoland
  • UK
« Reply #11 on: 28 January 2010, 12:46:39 »
The CVs simpler.....less gears  ;D
« Reply #12 on: 28 January 2010, 14:06:30 »
25 nm  :y
On a serious note, tighten them to 25 Nm then go over them all again a couple of times, as the washer does crush, meaning that they often need a second or third tweak to achieve the correct torque.
Found about 4 out of 6 of mine practically hand tight when I changed mine yesterday. :o
« Reply #13 on: 28 January 2010, 14:36:01 »
25 nm  :y
Most of mine were the same, and i know they were torqued correctly when fitted  :-/
« Reply #14 on: 28 January 2010, 15:11:04 »
You can't accurately gap a multi electrode plug! It's impossible.  :-?
